Desktop wallpaper
rrtek
Desktop wallpaper
#1 Post by rrtek »
I'm trying to locate the desktop wallpaper which comes with the G1 and M1.
Does anyone have it?
Regards.
Re: Desktop wallpaper
description?
the factory reovery image just has a solid white background.
#3 Post by Rob »
#4 Post by Rob »
But Shawn is right. Default is all plain white!
rrtek
#5 Post by rrtek »
Regards.
#6 Post by Shawn »
is this it?
#7 Post by Shawn »
posted at same time
rrtek
#8 Post by rrtek »
Yes, It is.
Regards.
#9 Post by Shawn »
Not perfect, but it's the best I could do.
I found a screen shot of the red Android version. I cropped it and then adjusted the color.
Meh--better than none I suppose. Red is not bad. I did not spend much time on the color swap to blue.
Last one is the original that I tweaked.
I fixed the blue lettering and reposted.
toughpad wallpaper 001.jpg (2.22 MiB) Viewed 22305 times
#10 Post by Shawn »
I tweaked the lettering some on the blue ones.
toughpad wallpaper 002b.jpg (2.13 MiB) Viewed 22304 times
toughpad wallpaper 003b.jpg (2.05 MiB) Viewed 22304 times
