CF-19 mk5 - two issues - brightness @ POST, bootup password
tsconard
#1 Post by tsconard »
I am having two issues with one of the mark5 units out of our fleet:
1. When the computer is cold booted, the brightness setting reverts to the minimum. I am able to adjust it up using the front panel buttons, or using Fn+F2. It will stay where I put it until the computer is powered off.
2. When the computer is cold booted we are presented with the bootup password requirement. I know the password and we are able to get in fine. When I enter the BIOS and disable all password fields, it appears to have no affect on this. I have reset BIOS values to default as well but it didn't help.
Any idea what causes these? Thanks.
User32
Re: CF-19 mk5 - two issues - brightness @ POST, bootup password
#2 Post by User32 »
Flat BIOS battery?
tsconard
#3 Post by tsconard »
User32 wrote:Flat BIOS battery?
This does not appear to be the problem. CMOS is holding the time/date and other settings normally. There are no warnings during POST about a possible battery wear issue.
#4 Post by Shawn »
Try changing the passwords to a blank space and save.
tsconard
#5 Post by tsconard »
Shawn wrote:Try changing the passwords to a blank space and save.
Shawn this is something that I wanted to try, but I don't even see the field that allows for password entry at this point. Do you know which menu it's in and what the option is? Thanks.
#6 Post by Shawn »
this page
You should be able to disable or change the password.
tsconard
#7 Post by tsconard »
Shawn wrote:this page
Ok, that did fix the bootup password. I missed the "user password" field. I was able to clear it.
The brightness issue persists though. Whenever the computer is cold booted it will default to the minimum brightness and that I have to adjust it. I am not seeing this as configurable in the BIOS.
#8 Post by Shawn »
use the hotkeys.
Fn +F5 and Fn+F6
tsconard
#9 Post by tsconard »
Shawn wrote:use the hotkeys.
Fn +F5 and Fn+F6
For this sytem, FN+F5 and F6 correspond to the volume controls. F1 and F2 are for LCD brightness. Those adjustments work, as do the front panel brightness buttons. The problem is that the brightness goes very dim when the computer is cold booted. I have to adjust it each time using those buttons.
#10 Post by Shawn »
I was guessing on which exact keys. I was typing on a CF53 and used those keys.
Look in BIOS for CONCEALED MODE.
