Panasonic Toughbook CF30 GOBI CEO168 WWAN
Jose_Ortega
Hi,
I have a CF30ktpax2m and I just got from ebay a GOBI CEO168 WWAN card. I just install the card and a tmobile sim but it doesn't work. Does anyone know what I suppose to do next? Thank you in advance.
Re: Panasonic Toughbook CF30 GOBI CEO168 WWAN
Model Number:
CF-30KTPAX2M
Status:
DISCONTINUED
MSRP:
$2,200
Description: WinXP (Vista COA), Intel Core 2 Duo SL9300 1.60GHz (Centrino2), vPro, 13.3" XGA Touch, 160GB, 2GB, Intel WiFi a/b/g/n, TPM1.2, Bluetooth, Single Pass (WWAN), No Drive, Toughbook Preferred
CF-30KTPAX2M
Status:
DISCONTINUED
MSRP:
$2,200
Jose_Ortega
This is what I see on screen
- uploadfromtaptalk1413703667675.jpg (41.71 KiB) Viewed 18826 times
Reason: fixed picture
Jose_Ortega
Please resize your photo to a smaller size.. Its way too large..
What brand of laptop did the card come from? You will need the drivers from that brand. IBM and HP cards only work in IBM and HP laptops.
Did you set the dip switches for the card?
Did you enable the WWAN in the BIOS?
Shawn wrote:Please resize your photo to a smaller size.. Its way too large..
Jose_Ortega
guys sorry about the pic I didn't realize how big it was(post it from phone Talk a pad app)Shawn wrote:Please resize your photo to a smaller size.. Its way too large..
Thank you you your response This card came out of another CF30. Shawn What is or where is the dip switches on the card? and how do you set it up? also I verify the Bios and I don't see anything saying WWAN enable/able.
I had download the drivers from http://www.panasonic.com/business/tough ... reless.asp and all the time it says that it doesn't find the WWAN or that is only for Panasonic
Did you swap the whole sled from the other CF30 or just the card?
The dip switches are on the sled.
Jose_Ortega
Well it was not my other CF30. I just got it from eBay and he said that it was taken from another cf30. I trying to see where is the switches on the sled but I don't see it.
