With:
DRIVE
CADDY
BATTERY (USED, WORKING)
DVD
SD READER
SMART CARD ON ONE
GENUINE PANASONIC POWER SUPPLY
One of these had a cheesy plastic keyboard protector on it. The touchpad shows minimal wear. These are nice for those that haven't tried one. 2.33GHz CPU, 60/7200 hard drive. They're quick. Edge scroll works as they are equipped with Synaptics/PS2 TouchPads.
Options:
A second caddy...rated "as new". $75.00 (includes instructions for installing drive.)
Lind Auto charger with ciggy plug. 40.00 NIB
Here's your chance to get a Linux (Ubuntu) machine...set up and working. You can always fall back on XPPro as these sport an XP COA on the bottom. But you won't want to if you give them a fair trial. At present there are 34,750 items available from the Ubuntu Software Center.
Operators are standing by to take your call.
