Some buyers requested to give some colors on cf-29 toughbook and so here is my initial response. As a matter of fact, I already sold one locally when he saw this type of combination and designed but on different color combination which is black(graphite) on the center and pure white on outer side. Will try to do as much as i can.
This one is a combination of Blue and graphite. I want to know your honest comment. I don't wanna do it but due to some buyers and growing demand. It is a must,Lol
- IMG_57051.JPG (182.61 KiB) Viewed 24585 times
- IMG_57121.JPG (311.12 KiB) Viewed 24585 times
- IMG_56981.JPG (229.46 KiB) Viewed 24585 times
Re: Some buyers requested to give some colors on cf-29 toughbook
I like the colors. Think it looks good but if it was me buying it I would like the Toughbook badge on it too. Good job.
I like this one too. It does look better with the Toughbook badge
- Teos 29.jpg (40.46 KiB) Viewed 24567 times
Oh! man. Your quick to see my listing. Dam.. there are a lot watcher but no offer yet. I think most buyer want have more junk plug n' play item rather than a grab and go unit, Lol..
I agree with Blair. Looks good. How durable is the paint or is it powdercoated?toughasnails wrote:I like the colors. Think it looks good but if it was me buying it I would like the Toughbook badge on it too. Good job.
Glen
Grim
I have a couple of questions for you about the painting of the lids.
1) what kind of paint do you recommend?
2) how durable is it once you have painted it?
I would like to paint mine in OD Green
Jerry
Jerry
I have not done a 29 but I have done a few 51's and 52's and they turned out great. I used Krylon and Dupli-Color "Perfect Match" auto paint , primer and 400 grit sand paper. This paint cost $4.00 - $8.00 range but it's good paint. I give it 4-5 coats and one I even used clear coat on it. The colors I have used so far are grey , black and purple
Teo,
I gotta say the blue and black and great, I saw them on ebay and had to check them out.
that would be ohlipcon (teo) ...he is the seller and started this thread. . He has done a few different colors and all look great.
