Keep an ear open for a March announcement of the New Business Rugged C1 convertable tablet!
UPDATE Picture Attached. Does anyone see a striking resemblence to the Fijitsu Life Books?
New convertable tablet
- c1.JPG (3.54 KiB) Viewed 18219 times
"Basically, I'm for anything that gets you through the night - be it prayer, tranquilizers or a bottle of Jack Daniels.” ~Frank Sinatra~
Re: New convertable tablet
The Panasonic C1 is the World's Lightest 12.1" Convertible Tablet PC
It will be announce March 2nd 2010 at HIMSS
First Ship Date will be June 1st 2010 (for Dual Touch units)
Two screen types will be available: Dual Touch (Digitizer and Touchscreen in one) & Touchscreen Only
Both units will also have Multi Touch capabilities in Touchscreen Mode
Business Rugged Unit rated for:
-30 inch operating drop (to base only)
-1ft drop on all 26 axis
-Magnesium alloy case
-Crush resistant to 225lbs
-Shock-mounted, flex-connect QUICK RELEASE HDD
-Spill-resistance keyboard
Highlights:
-Industries most Durable one handed triple-hinge design
-Multi Touch Capabilities
-Will feature the H1's patented ergonomic hand strap
-Ships with one 5 hour battery but will take 2nd on board battery and capable of hot swapping
-Will be capable of Bluetooth, WiFi, WiMAX, and GOBI Mobile Broadband simultaneously
-Will feature Intel's New i5-520M 2.40GHz processor
-5 programmable buttons on frame of screen for access in laptop or tablet mode
-Standard with a Dual Array noise canceling michrophone
Full spec sheets will be available tomorrow, after the press release, on Panasonic.com
Highlights:
If anyone wants to see the full spec sheet, let me know and i can email you the PDF.
Can you please post the PDF on here?
The Files are too large... i was going to try a screen shot jpg but then you cannot read the text.Rob wrote:Can you please post the PDF on here?
How big is big? because I have it set to like a 200MB limit......
yea they are over 3... how about some links?Rob wrote:How big is big? because I have it set to like a 200MB limit......
http://www.panasonic.com/business/tough ... _Sheet.pdf
http://www.panasonic.com/business/tough ... ochure.pdf
Check this out: http://www.ubergizmo.com/zoom.php?dir=2 ... ic/&page=4
The 5th pic... it doesn't appear to have Aero enabled... does it maybe not support Windows Aero???!?!?!
Not sure, but in my experience the Healthcare industry that this is designed for locks everything down and uses proprietarty software suites. So this option is of no concern for them.Rob wrote:Check this out: http://www.ubergizmo.com/zoom.php?dir=2 ... ic/&page=4
However, i don't see any reason why this wouldn't be capable of Aero.
