dGPS retrofit
dGPS retrofit
I tried using the dGPS Mk2 module on an Mk1 unit, but it didn’t work. I’m wondering if they’re compatible or if the Mk1 needs a BIOS reflash to support the Mk2?
Re: dGPS retrofit
Is GPS turned on in BIOS? I havent had one of these but all the older models you had to have it turned on in the BIOS for it to work.
