cf30 mk1 backlite keyboard
Re: cf30 mk1 backlite keyboard
Are you looking for the rubber one or the plastic one?
Also the ones on the CF-31 will also fit.
junglewarrior
I have one with a rubber keyboard I didn't know there was also a plastic one which makes more light?? my rubber one is low light ... thanks from italy
Three basic keyboards. Standard plastic one. Back lit rubber one (that can be a pain to type on) and the Emissive keyboard that is the plastic backlit one. The rubber one is still the best one for wet and sandy places to keep stuff out. ALSO be aware for CF-18/19 models we have seen copies of the Emissive keyboard from china but they don't have a backlight on them. They may have expanded into 30/31 market but I am not sure. On standard keyboards you will see two plugin cables. The backlit ones have 3.
