Team,
Previously you would go to "toughbooktalk.com/p" and it would redirect to "toughbooktalk.com/public_downloads". I've changed this a bit and it is no longer done in the aforementioned way. I want to re-iterate, Like the forums, the data is all there from before, nothing has been lost either! We're only using about 23.2GB of data as well, so nothing crazy!!
The new downloads folder is located at: http://downloads.toughbooktalk.com where you will see all of the data that was there from before.
Additionally, I just beefed up the maximum posted file size limit to 1GB (gigabyte) across the boards/forums! I think this should help everyone! If anyone has anything they want me to add (Drivers or cool wall-paper as 2 simple examples) that they want for their "Contributing Members" folder located here: http://downloads.toughbooktalk.com/Cont ... 20Members/ , post it here and I can get it uploaded to the downloads section for the world to see/share/access.
Feel free to chime in and post the files here right on the forum (Best to ZIP them up if they are .exe files!!). Also if 1GB is not enough I can increase it further but I think 1 gig should be a good start!!!
New link for Public Downloads / File Share Forum HERE!
Re: New link for Public Downloads / File Share Forum HERE!
test big file size
- GOBI 5000 Drivers.zip
- (1015.41 MiB) Downloaded 769 times
Team,
The big gray download button was going to the old/wrong download link. This has been fixed. If you click it it will now go to the new downloads.toughbooktalk.com site!
