CF-54 Mark 2 w/ MX17 Horizon.
#1 Post by SHEEPMAN! »
This is the first tweak I have had to do with CF-54F0001VM. Touch was spot on. Wacom multi-touch is supported.
http://forum.notebookreview.com/threads ... t-10693689 should let you see both posts.
Re: CF-54 Mark 2 w/ MX17 Horizon.
Cut n paste of Jeffs posts
Here's my hearty recommendation for Linux for CF-54 MK2.
Works out of the box. Touch spot on and multi-touch works.
UEFI disabled in bios at the present time.
Kernel: 4.14.0-3-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3
Distro: MX-17_x64 Horizon
Kernel is upgraded via MX-Package Installer to MX 4.14 Kernel Meltdown Patched, 64-bit then cloned for LiveUSB or copied via Snapshot and saved as snapshot.iso.
Speaker Jack may not be functional with some Linux Distros.
This is my first tweak for MX17 Horizon.
This writes a PERMANENT file called sound.conf and enables a feature in snd-hda-intel. Call it a software switch. W10 does this automatically.
Code:
$ su
Password:
root@mx54:/home/m17# echo "options snd-hda-intel model=headset-mode" > /etc/modprobe.d/sound.conf
To remove the file:
Code:
sudo rm /etc/modprobe.d/sound.conf
Waiting on a mike for this headset...so mike untested.
and this one :boing:
#3 Post by SHEEPMAN! »
Custom desktop.
UNCNDL1
#4 Post by UNCNDL1 »
I see from your screenshot that there are updates ready to roll.
I’m loving the same operating system on my 52 & 53.
Thanks Lefty!
