Screenshot of Conky antiX17
#1 Post by SHEEPMAN! »
Check the ram usage. First part is cut and paste from
$inxi -F
Bios set to touchscreen....otherwise broken.....but that was before update and upgrade. I added xinput from package manager.
Atheros/Broadcomm card was hard blocked....switched to 5100.
Todo list: Try with touch set to auto.
System: Host: antix1 Kernel: 4.10.1-antix.1-486-smp i686 bits: 32
Desktop: IceWM 1.4.2 Distro: antiX-17.a2_386-full keerfa 19 March 2017
Machine: Device: laptop System: Matsushita product: CF-52GUNBR2M v: 002 serial: N/A
Mobo: Matsushita model: CF52-2LTA v: 1 serial: N/A
BIOS: American Megatrends v: V2.62L13 date: 06/08/2009
Battery BAT1: charge: 86.6 Wh 100.0% condition: 86.6/86.6 Wh (100%)
CPU: Dual core Intel Core2 Duo P8400 (-MCP-) cache: 3072 KB
clock speeds: max: 2267 MHz 1: 2266 MHz 2: 2266 MHz
Graphics: Card: Intel Mobile 4 Series Integrated Graphics Controller
Display Server: X.Org 1.19.2 driver: fbdev Resolution: 1024x768@0.00hz
OpenGL: renderer: Gallium 0.4 on llvmpipe (LLVM 3.9, 128 bits)
version: 3.3 Mesa 13.0.6
Audio: Card Intel 82801I (ICH9 Family) HD Audio Controller driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.10.1-antix.1-486-smp
Network: Card-1: Intel 82567LM Gigabit Network Connection driver: e1000e
IF: eth5 state: down mac: 00:0b:97:de:9d:f0
Card-2: Intel WiFi Link 5100 driver: iwlwifi
IF: wlan6 state: up mac: 00:1e:65:65:3d:e6
Drives: HDD Total Size: 160.0GB (4.3% used)
ID-1: /dev/sda model: Hitachi_HTS54501 size: 160.0GB
Partition: ID-1: / size: 144G used: 4.5G (4%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 2.15GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors: System Temperatures: cpu: 54.0C mobo: 49.0C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 170 Uptime: 2:46 Memory: 245.6/1885.2MB
Client: Shell (bash) inxi: 2.3.54
