connector type
connector type
#1 Post by teo »
Can somebody identify this type of connector(the one with red arrow). I've tried the net. but I can't compare it.
Re: connector type
any numbers on it anywhere?
RDJack
Re: connector type
#3 Post by RDJack »
Hi Teo,
Do you have the model number of the computer? If so, I can try and get a service manual which may shed some light on what that connector is.
Thank You
User32
Re: connector type
#4 Post by User32 »
I'm quite sure that's a CF card connector: https://www.google.com/search?q=CF+card+connector
Re: connector type
#5 Post by teo »
This connector is from PARmobile that I bought a couple of weeks ago. Link: https://www.ebay.com/itm/Smartmatic-PAR ... 2749.l2649
This computer is great for mobile server and the screen it also great. The only setback is the fan is so noisy. It can be hear maybe up to your neighbors, lol...
Shawn, I will check if I can find any no.
User32, I think your right! Thanks
