Hi folks,
I got my new (use) mk5 and I'm really happy just got install all my software. So I get some issues with gobi card and my sim card. I'm not sure how i'm supposed to connect it. I have qualcomm gobi 200 hs-usb modem 250f and I would like to connect on telus network. I found on the hard drive ''csa'' folder with the driver for Qulacomm modem and found ''csa'' software. Thats gave me 3 provider so then I'll tried with at&t and then after the configuration I got signal and saw my text message save on sim card but I couldnt press connect. So I download Sierra wireless skylight software but doesn't look to works?
Do you know which software I should use with Qualcomm modem?
thanks
wwan how to use with canadian provider
Re: wwan how to use with canadian provider
