Looking for CF-74 HDD cover
CF-74 HDD cover wanted. Anyone??.....
We get some rules to follow.
Re: Looking for CF-74 HDD cover
Thanks Shawn, just need the cover, have caddy.
edit - The plastic side cover that keeps the caddy from falling out of the toughbok - end edit
Do ya have the number on that Rich?....Busy sort of but there MAY be one here. Maybe Kerry has one.
Hi Jeff,
I think maybe I'm mistaken. Been looking for part number, no luck. Is the side cover (trim) molded into the caddy? I thought it was like on a CF-53, maybe its not. I've got a 74 showing up Friday with caddy and I was looking at photos which was probably causing the confusion. Will wait til it's in my hands before I make any more ASSumptions. Ha Ha.
That's why I was confused. The 74 does not have a cover like the 53 does
Thanks Shawn, I found that last night and spent an hour or so pouring over it. I think somehow I got confused by the CF-53 trim cover.
Rich
Rich
