These useless POS Versacraps on CF31's REALLY annoy me.
The Synaptics touchpads were so much easier to use. They had 100 times better software and drivers.
I can not crop a simple photo using this Versacrap. It will move to the next image evry time I let up.
Or it refuses to save the crop lines.
I have used the software package for over ten years. Irfanview...
Versapad aka Versacrap
Re: Versapad aka Versacrap
Is it too sensitive or does it accelerate too quickly?
neither.
It's hard to describe. But if you use one, you will notice the difference.
One thing is if you click to select an area on a photo..then drag to enlarge the selected area..it is ok until you lift your finger, then the selected area is lost.
Sometimes when you lift your finger, it auto jumps to the next image.
