CF-31 Model letters within Marks
Geraout
#1 Post by Geraout »
Hi All.
I'm in the UK looking to buy a CF31.
I've found a list of model numbers corresponding to marks at Toughbook Central (although it stops at CF31 Mk2).
My question is - what are the differences between the letters within each Mark?
eg a Mk 1 CF-31 includes model letters A,B,C, D,E & G. Mk2 covers model letters J,K,M,N,P,Q & R.
So is a Mk2 2 R model better than a Mk2 J?
I've googled and downloaded a number of spec sheets but none show any reference to model letters with marks.
Hope that makes sense
Re: CF-31 Model letters within Marks
You can type the full number into this handy tool. It must be the exact format. 1 extra space and it will fail.
Use the search by model number box.
http://www.panasonic.com/business/ifram ... urator.asp
Geraout
#3 Post by Geraout »
Thanks Shawn.
Yes - I've seen the configurator mentioned in this forum, but you need to have a full model number to use it.
Perhaps I'm misunderstanding it - is a Mk2 "R" version a later (improved) version compared to a "J" version or they just differing configurations of a Mk2?
Usually with model numbers (TVs, phones etc) a higher letter or number denotes a (usually) better spec.
#4 Post by Shawn »
Different configurations of a mk2 is correct.
The only major difference is if it is a high performance model with a dedicated ATI graphics card.
#5 Post by Shawn »
Stolen from the web.
Fully-rugged MIL-STD-810G and IP65 certified. 13.1" 1200 nit LCD. Mobile broadband ready. Optional 3G Gobi™ or 4G LTE mobile broadband.
Toughbook CF-31 replaced CF-30 in 2010. Up to date there are 5 versions of Toughbook 31.
2010 MK1 CF-31A
2011 MK2 CF-31Q/J Core i3 or Core i5 2.5GHz
2012 MK3 CF-31S Core i3 or Core i5 2.6GHz
2014 MK4 CF-31Y Core i3 2.5GHz or Core i5 2.7GHz
2015 MK5 CF-311 Core i5 2.3GHz
CF-31A
CF-31B
CF-31E
CF-31C
CF-31D
CF-31G
CF-31J
CF-31K
CF-31K Value Core i3
CF-31M
CF-31N
CF-31P
CF-31Q Value Core i3
CF-31R
#6 Post by Shawn »
That one was messed up when I converted from a spreadsheet to a jpg
Makes me crazy people using a spreadsheet format for information that should be in a document format.
#7 Post by Shawn »
Sorry that last one got screwed up in the conversion to a jpg.
This one is better
Toughbook model list corrected.jpg (278.42 KiB) Viewed 23705 times
Geraout
#8 Post by Geraout »
Excellent - thankyou for your time.
