Screen protector replacement
Where do I get a replacement protector? My current one is quite used and worn.
Re: Screen protector replacement
From Rugged Depot of course!
But seriously the OEM screen protectors are a PITA to install..
Also, I need your FULL model number as there are two different sized screens in CF-19's!
19 Mk6, with the 10.1 screen.Rob wrote:From Rugged Depot of course!
So, i'm better off leaving the worn one on the screen instead?
Unless you have a clean room it's literally I-M-P-O-S-S-I-B-L-E to get the new factory OEM one on there without getting dust behind it.
FYI they are $75/each
Alternatively, we have generic ones that you can see the glue on all 4 edges but there won't be bubbles. We have been using these for many refurbs these days. Those are $35/each
