CF-30 Battery Light flashing
dryster
#1 Post by dryster »
I noticed in the middle of the night that one of my CF-30's green battery light was flashing and so I plugged it in and it's still flashing but the TB does not start or even go to the BIOS screen. Anyone know what's going on?
CF-30C with standard keyboard and Windows XP.
CF-30K x 2, both running Windows 7.
CF-19F. Windows 7.
It's difficult not to collect these things.
dryster
Re: CF-30 Battery Light flashing
#2 Post by dryster »
I've read in the manual that "In high temperature mode, the battery pack is discharging the power to 80% of normal temperature mode. Do not remove battery pack in this status" which would make sense if I could boot the TB but the unit is unresponsive.
I did remove the battery and tried it in another TB and it works, this CF-30 appears to have gone to TB heaven as even with no battery and no HD in it does not POST any more, I expect the flashing light was a cry for help from the battery "Get me out of here"
CF-19F. Windows 7.
#3 Post by Shawn »
Do the power pull reset thingy.
1. Pull battery.
2. Dis-connect power supply.
3. Hold switch on for 20 seconds...repeat several times.
4. Plug in power supply. (not the battery yet)
5. [F2] [F9] [F10] (boot to bios, set to defaults, save)
dryster
#4 Post by dryster »
Hi Shawn, tried that just now. After doing it, using a known good power supply the power "Z" light next to battery light does not illuminate. If I cycle the power on switch the HD light flashes once only (does not flash on subsequent switch cycle) - I will try the power pull thingy a few times with hope in my heart but I fear the worst for this patient.
It solves a problem though, this is a CF-30C and I have CF-30K with no caddy, so there will be a heart transplant with no extra cost to me and eBay will get a parts machine.
CF-19F. Windows 7.
#5 Post by teo »
Try first to replaced the ram with a good known RAM before you go anywhere. One slot at a time. Pull out known ad on hardware like wireless card, media drive, harddrive and etc.
#6 Post by SHEEPMAN! »
What he said. Sounds like a bout I had with ram last week and several other times.
When you find the bad ram break it in half....that particular stick gave me trouble before.:D
Bill_TN
#7 Post by Bill_TN »
:clapping: :pbjt: So happy when good advice gets shared. :pbjt: :clapping:
#8 Post by Shawn »
Now here is a story of one BAD ram. This is for you Jeff. :rofl:
http://www.dailymail.co.uk/news/article ... track.html
Must watch video. :swords:
http://video.dailymail.co.uk/video/1418 ... s-bike.mp4
#9 Post by SHEEPMAN! »
This is good ram.
2016-04-23 13.21.46 (Mobile).jpg (110.43 KiB) Viewed 20438 times
This is why.
2016-04-18 18.58.09 (Mobile).jpg (68.51 KiB) Viewed 20438 times
#10 Post by Shawn »
Cute twins
