Hello fellow toughbook enthusiasts,
I'm quite depressed to report that my Toughbook Y4 no longer accepts power from its brick. Nor from the replacement brick
I acquired last time this happened. It was sad to be using it, plugged into the wall, watching the battery slowly drain, knowing
that there would be no coming back from 0%.
This is the third time I've seen this problem; the first time, it started working after a little bit of time. The second time, I
bought a new power brick, and by the time it arrived in the mail, the laptop was working again. I'm not sure if I'm burning through power bricks or not, but I suspect a problem with the voltage regulation/socket on the motherboard. Maybe I'll be lucky and the socket is no longer soldered well, or there's an obviously bad solder joint that I can fix.
In any case, I come here seeking advice and mayhaps a Service Manual, before I pull out the multimeter and open this old friend up.
-TJ
Edit: Full model number is CF-Y4HWPFZBM
CF-Y4 Repair-- No power. (Repair manual? Tips?)
ToughbookLover
Re: CF-Y4 Repair-- No power. (Repair manual? Tips?)
I would have to say that unfortunatly the power plug is probably shot. While this can be soldered with a skilled hand (I could do it for sure), it is better to replace the motherboard.
I've attached a few service manuals for you as well
Welcome to the forums as well
- CF-Y4 Mk 2 schematic.pdf
- (1023.74 KiB) Downloaded 679 times
- CF-Y4 Mk2.pdf
- (104.74 KiB) Downloaded 813 times
- CF-Y4 Mk2 board.pdf
- (686.88 KiB) Downloaded 755 times
ToughbookLover
Thanks for the manuals, Rob. Unfortunately the promising-looking "Service Manual" (the second link) is only 2 pages long-- looks truncated to me.
I disassembled my Y4. The power connector is not directly soldered to the board; there are actually two wires that lead to a connector on the
motherboard, presumably to make it much more resistant to breakage.
So what's wrong? I have no idea. I do know that if I connect power to the laptop (while open), I can hear a "ticking" (an electronic power switching sound)
about once a second.
If I disconnect the CD-ROM drive from the motherboard, then the LED in the power switch lights up in time with this ticking. I can actually disconnect
everything from the motherboard and still hear this ticking. (and the LED will light if that part if is connected, as long as the CD-ROM is not.)
So, there's power... I expect the flashing is some sort of trouble code, but I have no idea how to interpret it.
Any suggestions or good sources for motherboards? I see a seller on ebay who is selling both a used Y4 for $300, and the parts from a stripped Y4 including
the motherboard for Y4. But, sketchy... Maybe I just need to let go. But how will I get 1400x1050 in a 3.3lb package?!
-TJ
-TJ
ToughbookLover
For the record, I obtained a Y5 service manual at http://toughbookforum.com/viewforum.php?f=32 which is probably similar enough.
(It also did not help.)
TJ
TJ
