I installed Windows 7 on my CF-19 and used the Vista drivers for the buttons, but they're a bit wonky (brightness does not work, flip screen) - should I be "tricking" the system and install the MK3 buttons and pad drivers?
Thanks.
CF-19 MK2 Windows 7
CF-19 MK2 Windows 7
CF-30C with standard keyboard and Windows XP.
CF-30K x 2, both running Windows 7.
CF-19F. Windows 7.
It's difficult not to collect these things.
CF-19F. Windows 7.
Re: CF-19 MK2 Windows 7
It can't hurt. With W7 some times you have to try other model drivers.
Or you could try the correct driver package for win7 cf19 mk2
ftp://ftp.panasonic.com/computer/softwa ... 2-7x86.exe
Thanks Shawn, but how come the Panasonic driver selector does not know that, they just don't want to show that they support the MK2?
CF-19F. Windows 7.
CF-19F. Windows 7.
Even though that package installs apparently flawlessly, still the side buttons for rotate and the one next to it do not work.
CF-19F. Windows 7.
CF-19F. Windows 7.
And of course, flawlessly installing a bucket load of stuff with one click has consequences, the hotkey appendix runs the CPU hot, running 50% of cpu capability, I thought it was my new w7 install svhost background taking up all the cpu horsepower, but no, it's the hotkey appendix.
CF-19F. Windows 7.
CF-19F. Windows 7.
