hi there,
installed a LAN PORT on an fz-g1
but it will NOT show up on device manager
and LAN PORT WILL NOT WORK.
any one out there with a solution ?
kind regards
may god bless you and family
matt
FZ-G1 LAN PORT INSTALLED. NOT working.
abcdcomputers
kindly email
MYDEARCOMPUTERS@HOTMAIL.COM
OR CALL CELL 630 290 1727
address: 720 S main street
Lombard IL 60148 USA.
REGARDS
MATT
REGARDS
MATT
Re: FZ-G1 LAN PORT INSTALLED. NOT working.
Always do a battery pull reset.
1. Pull Battery/ies.
2. Pull power.
3. Hold power button down until your finger gets tired.
4. toughasnails says/said un-plug cmos battery.
I have posted this about a hundred times.....would someone say if it ever worked please. I didn't make it up, I got my info from teo, Rob and others.
What I made up is the saying "drain the stupid from the motherboard".
At the end "SET BIOS TO DEFAULTS".
2. Pull power.
Jeff,
Yes the reset has worked for me once or twice.
