It is currently Fri Jul 10, 2020 12:56 am
PostPosted: Sat Dec 05, 2009 6:56 pm
I've seen that the RAM on a CF-18 can be upgraded to 1GB. From what I can tell PC2700 DDR 333mhz SO-DIMM RAM is what I can use, but can I use others? I see PC 3200 at 400mhz etc...being offered, but don't know enough about all the numbers to know what is needed and what will be wasted or how to tell where the cutoff will be in these stats. Any help?
PostPosted: Sat Dec 05, 2009 8:37 pm
Did you figure out the mk#
It sounds like its a mk1,2 or 3 if you need ddr ram
Mk-1s come with pc2100
Mk-2's and 3's pc2700
Pc 3200 should work ok although I have only tried pc2700
Make sure its not ddr2 if you don't have a mk4 or mk5
Alex
PostPosted: Sat Dec 05, 2009 8:50 pm
Yes, it's a MK2, CF-18DHB22KA. I see that originally it was assumed that only 512mb of RAM could be added, then 1Gig, so wondered if PC3200 2gb stick would also work or if it capped out at the 1gb?
Aside from upping the RAM, I figure I'll throw in a 320gb HD. As far as wireless goes, I know little to nothing. I see it has various antenna, but not sure which are still useful and which are obsolete.
I'm very much wanting to invest in the custom GPS/Bluetooth units being sold since my TB is lacking GPS, but no idea what I need to be doing to upgrade it's "WiFi-ness" if indeed that is a thing. Any suggestions?
I've rebuilt engine and whole vehicles and I'm very mechanically inclined. Played a lot with desktops too, but only hardware and never laptops so this is all new ground and I'm looking forward to the learning curve.
PostPosted: Sat Dec 05, 2009 9:40 pm
Even assuming that the 2GB stick would work (and I have strong doubts it would), 1.5 will still be the max recognized. The stock wifi is probably a 2100 (maybe a 2200 Intel). If it is a 2200, you can use that for now, but a switch to the 600mw Engenous would be the logical choice as it is the standard around here as long as you do not desire to go into the "N" range. The stock antennas (if so equipped) will work fine.
PostPosted: Sun Dec 06, 2009 12:08 am
Please provide a link to 2GB ram
I have never seen 2GB DDR1 Ram , Its normal to see DDR2 in 2GB though
I don't want you buying the wrong ram!
Alex
PostPosted: Sun Dec 06, 2009 12:41 am
Hey Alex, the pictures of my latest art work are posted on the other site. Take a look and tell me what you think.
