Keyboard options...
Keyboard options...
what backlight options are available for a 19 keyboard? All I have been able to see are rubber, don't like those, are there emissive-chicklets for the 19? And if so, do we have a part #; or does anyone have one available?
~Paul
Philippians 4:6-7"
Panasonic CF-29 Toughbook - 1.6Ghz - 100 GB 7200 RPM HD - 1.5GB of RAM - GPS - Internal WiFi - Sierra Wireless EVDO - 13" Touchscreen - DVD/CDRW Drive - Media battery - BT enabled with BT PCMIA mouse - backlit keyboard -
Anyone for a game? Look for Doobi!! :p
http://www.letsplaychess.com
Philippians 4:6-7"
Re: Keyboard options...
I would love if one was available
But only the two types available ,rubber backlite and a standard type keyboard
Alex
Alex
hi guys, been reading here and there (very busy as usual) and nice lot of cf-19"s Rob. i have recieved a new rubber backlit keyboard from ebay and it types, but the backlighting is not working. using my fluke scopemeter i varified there is no power at 4 pin connector. is there a switch that needs to be flipped? i bought this cf-19 new from a dealer, so it's never been apart before today. the model number is cf-19c6gaxvm
when i installed my cf-30 backlit chicklet i had no issues worked right away.
thanks,chuck
thanks,chuck
Its plug and play...no switches ,
Did you try reversing the small flat cable
Alex
Alex
- Silver Trooper
This may sound like an obvious question, but did you try to adjust the lighting level with the FN + F12 keys? The ribbon cable develops a memory of sorts so it should go in the way that it "lays".
