ip security cameras
Mxx20
ip security cameras
#1 Post by Mxx20 »
Anyone have mich experiance with them? I have a zmodo one, works great but is there any software to run on a computer to act as a dvr? The software from zmodo doesn't really do it. I've found a couple but I'm just curious of anyone had experience with any.
Re: ip security cameras
#2 Post by SHEEPMAN! »
My daughter just put a guy away for two years with their system....kind of a cheapo.
I could monitor cameras online w/W7. They are closing / selling the store.
So what is a dvr? I am not sure if it was connected with alarm system or not...thinking not.
If you really want to know the set-up I'll have her email you......
#3 Post by Shawn »
dvr= digital video recorder
Toughbook
#4 Post by Toughbook »
While building my house I had them run the lines for an 8 camera HD DVR system. I still need to tweak it a little... One line was a bit short so I have an extension on the way. It is a hard wired system but the whole thing can be hooked up to the Internet so I can look at what is going on at any time.
I am still learning the system. I also have an IP camera somewhere in the basement that I bought to keep an eye on the neighbors hellions that were tearing up the neighbor hood several years ago... But they ended up moving before I installed it. It tested out great though.
Being out in the sticks I wanted something to keep an eye on things. The DVR will eventually go into my Safe Room/Armory. If they can get past 3/4" steel... They may have the DVR and contents!
Mxx20
#5 Post by Mxx20 »
Hmm, i dont have a dvr yet, it just snaps a picture when theres motion. I want to figure out a way to record like a 72hr loop and use the pictures it snaps for time stamps. But im only finding software to work with a dvr for a security system, i dont have one for the cam, it just streams over wifi... im suprised im not doing to good finding a software to act as a dcrllvr with the signal
Toughbook
#6 Post by Toughbook »
I would think you should be able to find software and use your PC as the DVR...
#7 Post by Rob »
I install, manage and engineer systems with Panasonic. From $10k - $500,000+ security systems.... Ones that you'd see at the casino.... All IP
My main system at my company HQ that I installed and programmed 100% is worth over $350k and I also have one set up at my house built on a budget high end system with Panasonic which is about $10k
All Panasonic. (Of course right)
#8 Post by SHEEPMAN! »
Sannce 960 dvr w/two terabyte hard drive. So that looping does not wipe previous footage. 8 cameras.....some inside some outside (weatherproof)...ir capable.
Internet view through xmi.net.
Not connected to alarm system.
FWIW. (that's all we know)
Mxx20
#9 Post by Mxx20 »
Rob wrote:I install, manage and engineer systems with Panasonic. From $10k - $500,000+ security systems.... Ones that you'd see at the casino.... All IP
Thanks rob, ill deff be calling maybe you can help with some insite on what do to with what im trying to do. Im just on a much smaller scale. 1 cam for now, maybe a few later on.
#10 Post by Rob »
No worries :)
