USB Borescope
USB Borescope
#1 Post by ADOR »
http://www.ebay.com/itm/400980683624?_t ... EBIDX%3AIT
Has anyone here bought or used one like this? I am looking at getting one. They have one that plugs into a computer port to be viewed on the computer screen. The one listed plugs into a android phone and is viewed on the phone screen. I am looking at adding more stuff to my hot rod stuff and this looks like the ticket for checking pistons.
Re: USB Borescope
Looks like something the Dr wants to use...
END-o-scope....
One with better resolution would be great connected to a FZ-A1 with the 10" screen.
the Ebay one is only 480x640...In my experience building the microscope camera, 480x640 is not enough resolution.
Re: USB Borescope
#3 Post by Shawn »
This one does 1280x720 images...And can be run on a Windows machine.
http://www.ebay.com/itm/Mini-Dia-5-5mm- ... SwWKtUrkFp
Mxx20
Re: USB Borescope
#4 Post by Mxx20 »
Ive got one, had a second one not to long ago(dad wasnt happy with his, couldnt see rifling well in .22 barrels). I use mine to look in cylinders at work and what ever else it fits in lol. I like it better than the snapon hand held units
http://pages.ebay.com/link/?nav=item.vi ... 35&alt=web
Kinds like i got but mine has the smaller head to fit thru the injector cups on the diesels
Re: USB Borescope
#5 Post by ADOR »
I am just looking for one small enough to fit through cylinder head spark plug holes. On my current 52 ford project and a few in the junk yard I want to see what pistons they came with from the factory. On some of them you can't tell unless you pull the heads. Trying to avoid all of that.
Re: USB Borescope
#6 Post by ADOR »
I higher resolution one would be nice, I will have to pick one up later on. I got the computer usb version for now. The cheaper one 10 bucks shipped. It came in a couple of days ago I just tried it out. I was thinking I was going to have to use the software that came with it. But everything I tried there software it locked up, etc. So I yanked it out of the CF-30 I had just put on charge and stuck it into my Alienware M11x. Then I tried the Yawcam software I use on it. The drivers installed plug and play so that wasn't a problem. Since the CF-30 was only at 3 Percent charge I just took the alienware out side to look at that piston. Yep, standard output 5.0 piston like I thought.
Re: USB Borescope
#7 Post by Shawn »
Hauppage WinTV7 works very nice for my camera setup.
Re: USB Borescope
#8 Post by ADOR »
Image1 (1) by Safjist Nipnog, on Flickr
Image1 (2) by Safjist Nipnog, on Flickr
Image1 (3) by Safjist Nipnog, on Flickr
Image1 (4) by Safjist Nipnog, on Flickr
It doesn't take too bad of pictures. Top of the 5.0 SO piston.
