I have two Lifebook U810's. I have played with them on and off over the last few years. I took vista off the second one and put 7 on it and tuned it up. Runs pretty good, better than I could get vista to run even after tweaks.
Now on the the first on I still have vista on want to load Linux to run some side by side tests.
It will need to be 32bit
here are the specs on the pc.
Platform Technology
Intel Ultra Mobile 2007
Built-in Devices
Keyboard, Digital camera, Display
Embedded Security
Trusted Platform Module (TPM) Security Chip
Processor / Chipset
CPU Intel 800 MHz A110
Cache L2 - 512 KB
Data Bus Speed 400 MHz
Chipset Type Intel 910GU Express
Memory
DDR2 SDRAM
400 MHz / PC2-3200
1 x 1 GB (max ram, can't upgrade, built in)
Audio & Video
Integrated Webcam Yes
Resolution (MP) 0.3 Megapixel
Capture Resolutions 640 x 480
Sound
Microphone
Audio Codec
Realtek ALC262
Hard Drive
40 gb
4200 rpm
Input
Type
keyboard, touch-screen
Communications
Wireless Protocol
802.11 Super AG, 802.11a/b/g, Bluetooth 2.0
Wired Protocol 10/100 Ethernet
SD card reader and compact flash port
Battery
Capacity
5200 mAh
4-cell
lithium ion
Connections & Expansion
Interfaces
1 x USB 2.0 - 4 pin USB Type A
1 x display / video - VGA - 15 pin HD D-Sub (HD-15)
1 x audio - line-in - mini-phone 3.5 mm
1 x audio - line-out - mini-phone 3.5 mm
Memory Card Reader
Yes ( SD Card, CompactFlash )
They have a dock for it but I don't have one.
Fingerprint reader (don't give a rats if it works or not)
Monitor 5.6 in
Aspect ratio 16:10
Resolution 1024 x 600 pixels
Dimensions & Weight
Width
6.7 in
Depth
6 in
Height
1.3 in
Any Idea what flavor might work best on it being only 1gb of ram and 800 mhz single core? I plan on a ssd later on it it's life. Under vista I tried ready boost and under 7 on the other unit though the Compact Flash port, I couldn't get it to work. I haven't tried the SD port yet. I have a dual micro sd card to Compact Flash adapter I plan on using to increase the storage on these units. Just got to get some more micro SD cards.
Trying to decide what to load
Re: Trying to decide what to load
From looking at your cars, you want something stylish.
Give MX-14 a look. XFCE desktop. Porteus works on rigs with smaller motors. 32 bit NON-PAE.
Training time....Cleve will be along......this is his forte.
Good choices Sadlmkr, MX-14 "symbiosis" found here:
http://www.mepiscommunity.org/mx/
Here's their wiki:
http://www.mepiscommunity.org/wiki
The videos are great teaching aides,
This would be my first choice as it is lightweight and works well with a CF-28.
Here's their wiki:
Just got home last night, downloading now. Lets see how it works when I give vista the boot. That processer is the forerunner of the atom, I just wish I could up the ram on it and not be stuck at 1gb, but hey at least it's not 512.
Looks like a fun toy. Heck I can't even find one on fleabay.
If you want a little one it's from the old UMPC market. I have one that runs xp that is smaller than a cell phone.
I have a Samsung tablet with 7" screen Q1, OQO 01+, HTC Shift x9500 and a few others. On the U810 it is also known as the u1010, there are a few more varations of it as well. In the life book line if you want one a little bigger I think they have ones in a 10" screen and a 12" screen that are dual core.
Here are a few of the ones I am talking about, some I see the prices have gone way up since I snagged mine.
http://www.ebay.com/itm/Fujitsu-LifeBoo ... 33a7ee118b
Here is a little one with a 8.9 inch screen, touch, slim and dual core. Haven't had one yet. http://www.ebay.com/itm/Fujitsu-P1630-2 ... 2c9fd50068 there are others in the lifebook like like it.
http://www.ebay.com/itm/Sony-VAIO-VGN-U ... 419bbc085d
http://www.ebay.com/itm/Sony-VAIO-UX380 ... 35f05fab45
The sony ux series were all core solo from the factory but a group on a forum did make a few core 2 duo by doing a CPU swap. Yes it required a hot air machine.
http://www.ebay.com/itm/HTC-Shift-X9500 ... 4d2c39bb2e
I have this one, battery life sucks, dual OS one is stuck in italian haven't gotten it running. Runs better with 7, but I need to get back to that one and see why the wifi isn't working anymore on it. The keyboard slides out and then it folds open to hold the screen up.
http://www.ebay.com/itm/ITRONIX-IX750-G ... 28065ab51e
I haven't seen one of these on the bay in a while. Always wanted one, but parts are hard to find. Since I got a U1 I kind of forgot about it. They used another brands motherboard to make it, don't remember right off hand, but it was a UMPC.
http://www.ebay.com/itm/Rare-Sony-VAIO- ... 2a572b67f8
can't leave the toughbook out
http://www.ebay.com/itm/Panasonic-Tough ... 25ab1bf369
http://www.ebay.com/itm/LIFEBOOK-LOOX-U ... 463f8343b6
http://www.ebay.com/itm/MINI-ORDINATEUR ... 419b68b51b
This is one of the smallest you can get. My note 2 phone is bigger, but the OQO is thicker.
http://www.ebay.com/itm/OQO-Model-02-5- ... 2a53a659da
http://www.ebay.com/itm/OQO-Model-02-5- ... 2ee576ac6c
On the samsung Q1 I do like it. I have two. One I coudln't get back working was a older style, and the best one is the "ultra" version. The ultra has a full keyboard as well. They can be had complete for under 100 dollars.
http://www.ebay.com/itm/SAMSUNG-Q1-ULTR ... 3ab09616ec
http://www.ebay.com/itm/Samsung-Q-1-Ult ... 35ed0c2bdf
http://www.ebay.com/itm/Ultra-Mobile-PC ... 35f080be57
My ultra has windows 7 on it now, 7" screen. These are still a good deal. There are several different varations, cpu speeds, etc so look them over good before purchase.
http://www.ebay.com/itm/BenQ-S6-2GB-Wi- ... 463778db1e
The benq s6 came in linux and xp flavors. SD card for expansion. It ran well. But was replaced with the Samsung. Jeff has it now, not sure what he is doing with it if he still has it.
http://www.ebay.com/itm/Viliv-X70-EX-7- ... 235787469b
http://www.ebay.com/itm/viliv-S5-32GB-S ... 3aafe8718b
Another option is one of these
http://www.ebay.com/itm/Craig-7-inch-Wi ... 3f52316805
Straight from the land of knock offs a 5 or 7" laptop running android. That is a older one running android 2.2, there are newer ones.
http://www.ebay.com/itm/7-VIA8880-Mini- ... 43e18d08b2
Time for another forum "The Little Guys". Sub-section of The Linux Forum works for me.
I still think MX-14 is classier than the puppy dog Linux versions. They are light but childish and not that easy to download/install. Oh, they work, but not for a
Paul, Send me one to put Linux on....better yet send it to Cleve.What say Rob?
Linux for little guys is a good idea...
Maybe Linux for old guys...Old laptops, not "us" old guys...
Every time I read the title of this thread I go sideways...
I am going off topic for a moment..
What to load..How about this and aiming at laptops running Windows 10.
It's a Pistola Con Caricato: 18-Shot Revolver, 3 Shots at a Time
Shawn, you crack me up...had to laugh.
Ador, here's a lot of 5 for $85:
http://www.ebay.com/itm/dealer-Lot-5x-I ... 1770627368
Shawn wrote:Linux for little guys is a good idea...
- Funding.jpg (41.52 KiB) Viewed 19775 times
