ISO a cf-hdd/batt bay cover.
In particular a cover that will fit a CF-28STMGZDM . My baby here has a hdd carrier, battery, 512mb internal ram and another 512 stick stuck in it. Just needing the cover to complete it.
- Springfield
Re: ISO a cf-hdd/batt bay cover.
I got this, send pm.
ok.
Bill, I have three/four complete CF-28...Do you want?
1. Springfield can fix your unit......then....
2. One of mine will fit the battery door that I sent you.
Remember the bad power plug.
{this is a one of a kind hacked in WLAN}
If you don't bite...these need to GO!
Messaged you JD .
Siiiiiggghhhhhhhhhhh. Still bottomless. LMAO
Still ISO a cf-28STMGZDM hdd/batt bay cover.
ok ended up ordering this from some one on e-bay. Hope it was a forum member. Just needed it to finish the 28 up. Thanks any ways.
What does ISO mean?
I have the machine boxed that matches the wrong piece I sent to you. Threw my back out lifting it. Maybe my Christmas.
Working my way through my list of promised items. Apologies to all.
