I am looking for a mk3 or later CF19 digitizer and pcb...at least I think I need the board.
It looks like I have the needed dual touch cable assembly. I need to verify that it's correct.
I have a mk4 unit I want to convert to dual touch. Currently it is touch only.
As far as I know it needs to be mk3 or later, the earlier digitizers and pcb's are different.
A busted LCD or top half that I could salvage parts would be great.
Wanted CF19 mk3 or better digitizer
Re: Wanted CF19 mk3 or better digitizer
part number is su5r-10s03au-2x
part number su5r-10s03au-3x may work..not sure.....that's from an H1..
If you want to turn a touch only into a dual touch I believe you are going to have to replace the motherboard as well. I don't believe there is a connection for the digitizer on a touch only motherboard.
Jack Shurtz
Tech Department Manager
Rugged Depot
281-305-5009
jack.shurtz@ruggeddepot.com
Jack Shurtz
Rugged Depot
281-305-5009
You are correct for a Mk1 or Mk2,
The mk3 and newer use the same connector for touchpanel and the digitizer.
The main cable is all that is different.
At least that is what others have experienced on the boards.
Ok, I wasn't 100% sure, I just remembered it was a different connector on the earlier marks. I will take a look through my parts and see if I have a digitizer.
Jack Shurtz
Rugged Depot
281-305-5009
Jack Shurtz
Rugged Depot
281-305-5009
Hi Shawn,
I checked my parts, unfortunately I do not have a digitizer from a MK 3 or above.
Jack Shurtz
Rugged Depot
281-305-5009
Jack Shurtz
Rugged Depot
281-305-5009
