CF-19CHBAFBE Mk1 Touchscreen Not Working Win XP
Banshee
#1 Post by Banshee »
So I've installed Windows XP onto a CF-19 Mk1 CHBAFBE and cannot get the touchscreen to work for the life of me :pat:
It's displaying in Device Manager as Fujitsu USB Input Device, the driver installs correctly however the touch input just does not work still.
I've been in the BIOS and it's showing as Internal LCD and NOT External Monitor before anyone suggests that.
Help, I'm stumped :(
Re: CF-19CHBAFBE Mk1 Touchscreen Not Working Win XP
What bios version?
I think xp and vista/win7 have a different bios for each of them.
Is there a setting in bios for tablet/touchscreen?
#3 Post by SHEEPMAN! »
XP must show Touchscreen in bios.
If Fujitsu is showing on a MK1 it means Touchscreen in bios and a bad touch panel or circuit. It's like a CF-30 MK-1.
If the problem turns out to be where the FPC plugs into the TSPCB....re-set then tape it down.
Edit: F must equal a WWAN for Europe...it's not on the configurator for North America.
Shop for new touch panel, just in case. Fairly simple to fix the third time you do it.
Banshee
#4 Post by Banshee »
The BIOS version is V1.00L16
No mention of the Touchscreen anywhere in the BIOS, I'm pretty sure it was working fine before I wiped it :pat:
#5 Post by Shawn »
CF-19CHBAFBE mk1
December, 2006 Europe
CPU U2400 (1.06GHz, ULV)
Touchscreen
80GB
512MB
802.11abg
TPM(1.2)
WWAN HSDPA (1.8Mbps)
Keyboard UK
Bluetooth
Operating system (XPP, English)
There are two BIOS update programs for CF-19[C/D] series:
Bios_19_1_r070207.exe - For upgrading to Windows Vista from Windows XP
After executing this program,
BIOS will be V1.01L16 and Embedded Controller will be V1.10L11.
Bios_19_1_r080013.exe - For re-downgrading to Windows XP from Windows Vista
BIOS will be V1.00L16 and Embedded Controller will be V1.00L11.
#6 Post by SHEEPMAN! »
What OS before you wiped it?
Linux LiveCD Mint 17 will show if the TS is working.
Is that model # the one from page 1(Main) of the bios? Sounds like the right bios.
:pat: The MK1 does not have the TS in bios. I stand corrected/reminded. :pat: That's why the bios and ec are changed from the registry.....and only the MK 1's of the CF-19 and CF-30.
If you had a tablet bios two hid items would show up under hid in device manager instead of Fujitsu.
Category:
BIOS, EC and Firmware
Title: BIOS V1.00L16 / EC V1.00L11 (Feb‚ 2008)
Model:
CF-19C/D/E(mk1)
CF-19[C/D]xxx[B/V]x (For XP Downgrade Model Only)
Windows Vista -> Windows XP
Operating System:
Language:
Release Date: Apr 18, 2008
File Name (Size):
[Download Time]
bios_19_1_r080013.exe (1.1 mb)
[Download Time 512k: 18.7 sec]
CF-19_BIOS_update_Manual.pdf (13.3 kb)
[Download Time 512k: 0.2 sec]
File Description
First Release
We will release the "BIOS/EC for Upgrading to Vista" and "BIOS/EC for
Re-Downgrading to XP" for 19mk1 XP Downgrade model.
This is the BIOS update for CF-19(mk1) Windows XP Downgrade Model only.
Sorry for the confusion.
Banshee
#7 Post by Banshee »
Linux Mint Live CD downloading as we speak
Can anyone link me to this BIOS version as the Panasonic site only shows the later one
This is the one I need by the sound of it
#8 Post by toughasnails »
Banshee wrote:The BIOS version is V1.00L16
You have the right BIOS now. I just checked my CF-19 MK1 and it has...
BIOS: V1.00L16
Embedded Controller: V1.00L11
The sound works great on mine with that BIOS. I will post a picture of my "device manager" so you can compare it to yours later on.
#9 Post by toughasnails »
Here is a picture of my Device Manager
CF-19 MK1 Device Manager.jpg (141.83 KiB) Viewed 22967 times
Banshee
#10 Post by Banshee »
Touchscreen doesn't work in Linux Mint 17.0 on a Live CD :wtf:
What does this mean?
