What every well equipped vehicle should have in the trunk!
- Silver Trooper
Just a few dollars for this set-up! I wish my Crown Vic (or the Trailblazer for that matter) were as well equipped.
- GR-loaded-trnk-try-in.gif (121.11 KiB) Viewed 14237 times
- GR-ld-trnk-try-plld-out.gif (130.08 KiB) Viewed 14239 times
Re: What every well equipped vehicle should have in the trunk!
SOOO BADASS! I just throw my Toughbook in to the truck of my SRT when going on long trips, otherwise it stays right next to me on the seat or on the floor...
Do you have the PDRC mounted int the front? The new one is coming soon but i can't get the specs out of Panasonic until we update our NDA. And when i do that i will know what coming but I won't be able to tell any one.
"Basically, I'm for anything that gets you through the night - be it prayer, tranquilizers or a bottle of Jack Daniels.” ~Frank Sinatra~
Don't worry, I'm sure I'll get the info before you anywaysredwoman wrote:Do you have the PDRC mounted int the front? The new one is coming soon but i can't get the specs out of Panasonic until we update our NDA. And when i do that i will know what coming but I won't be able to tell any one.
Welcome to the forums man!!!!
So u have specs for the 31 and the new silver H1 already then like I do?
redwoman wrote:So u have specs for the 31 and the new silver H1 already then like I do?
I don't beleve you
Convince me that you have that info, by listing screen size and resolution ,nits ,and backlite type on the cf-31
Alex
Had Prelim specs on the 31 last month, but can't find them right now. Here are some specific prelim model numbers right now. If i remember correctly i think they're going to 1000 nit on the non touch with the 31. Before it was touch at 1000nit and non touch at 500.
CF-31A3AAX2M * Win 7 Downgrade to XP * Intel Dual Core 2.4GHzV Pro, 13.1" Non Touch XGA, 2GB, 160GB, Intel WiFi a/b/g/n, WinXP, TPM, Bluetooth, No Drive, Toughbook Preferred
CF-31ACBGA2M * Win 7 Downgrade to XP * Intel Dual Core 2.4GHzV Pro, 13.1" Touch XGA, 4GB(2+2), 160GB, Intel WiFi a/b/g/n, WinXP, TPM, Bluetooth, Emissive Backlit Keyboard, Fingerprint, GPS, Dual Pass (Upper WWAN/Lower WLAN), Gobi, No Drive, Toughbook Preferred
CF-31ACBGA3M * Win 7 Downgrade to XP * Intel Dual Core 2.4GHzV Pro, 13.1" Touch XGA, 4GB(2+2), 160GB, Intel WiFi a/b/g/n, WinXP, TPM, Bluetooth, Emissive Backlit Keyboard, Fingerprint, GPS, Dual Pass (Upper WWAN/Lower WLAN), Gobi, No Drive, Toughbook Premier-3Y
CF-31ATAAX2M * Win 7 Downgrade to XP * Intel Dual Core 2.4GHzV Pro, 13.1" Touch XGA, 2GB, 160GB, Intel WiFi a/b/g/n, WinXP, TPM, Bluetooth, No Drive, Toughbook Preferred
CF-31ATNAX2M * Win 7 Downgrade to XP * Intel Dual Core 2.53GHzV Pro, 13.1" Touch XGA, 2GB, 160GB, Intel WiFi a/b/g/n, WinXP, TPM, Bluetooth, AMD(ATI) Graphics, No Drive, Toughbook Preferred
CF-31YCZC01 * Win 7 Downgrade to XP * Intel Dual Core 2.4GHz, V Pro, 13.1" Touch XGA, 4GB(2+2), 160GB, Intel WiFi a/b/g/n, WinXP, TPM, Bluetooth, Emissive Backlit Keyboard, Fingerprint, GPS, Dual Pass (Upper WWAN/Lower WLAN), Gobi, No Drive, Toughbook Premier-3Y
Here's what i have on the silver H1 to be known as the "Field Pro" model H1. It is in SWRI testing now and will have its offical Mil Specs and IP ratings soon. And there's a picture attached.
Intel® Atom Processor Z540 1.86GHz - 533MHz FSB, 512KB L2 Cache
64GB Solid State Drive (SSD)
2GB Memory1
Large, bright 10.4” XGA sunlight-viewable Dual-touch LCD - 1024 x 768 resolution (500 NIT with Circular Polarization)
- Supports gloved finger touch and digitizer pen
- Anti-gljiare, anti-reflective screen treatments - Circular Polarizer - Protective screen film
Extremely rugged
- Magnesium alloy chassis encased with polycarbonate
- Sealed all-weather design
- Ergonomic carrying handle
- Ergonomic hand strap
Wi-Fi (802.11a/g/n)
Bluetooth® v2.1 + EDR
Pop-up on screen keyboard
Interfaces:
o
Expansion bus connector
6 hour battery life with quick change batteries - Twin hot swappable Li-Ion batteries
Ultra lightweight 3.3 lbs. (with both batteries & strap)2
10.4”(L) x 10.6”(W) x 1.3-2.3”(H)
3-year limited warranty, parts and labor
XP Professional SP2 (with Windows 7 COA) or Windows® 7 Professional
Models
H1 Field Base
H1 Field Pro
o
2MP camera with dual LED light
o
2D barcode reader (1D and 2D capable)
H1 Field Elite
o
o
o
RFID & Contactless SmartCard reader
o
Insertable SmartCard reader
o
Fingerprint reader
Integrated options3
o
GobiTM 2000 (EV-DO, HSPA)
o
GPS receiver
Accessories3
o
AC Adapter
o
4-bay Battery Charger
o
Li-Ion Battery Pack
o
Replacement Stylus
o
10.4” LCD Protector Film
o
External USB Combo Drive
o
Desktop Cradle / 2-Bay Spare Battery Charger
o
Gamber-Johnson Vehicle Dock
o
InfoCase Carrying Straps, Sleeves and Pouches
2GB Memory1
Extremely rugged
Wi-Fi (802.11a/g/n)
Interfaces:
o
Models
H1 Field Base
H1 Field Pro
o
o
H1 Field Elite
o
o
o
o
o
Fingerprint reader
Integrated options3
o
o
GPS receiver
Accessories3
o
AC Adapter
o
o
Li-Ion Battery Pack
o
Replacement Stylus
o
o
o
o
o
- Field H1.gif (14.82 KiB) Viewed 14137 times
Interesting ,
Looks like the same 1024 x 768 resolution as the cf-30 ,with slightly smaller screen 13.1" in comparison to the cf-30's 13.3'
Sneek us a picture of the cf-31 if you find one laying around
I will have to have one to replace my old dated cf-30 mk-2
Alex
Alex
good catch... i didnt even notice the 13.1 inch screen. Why on earth would they make it a different screen from the touch 52 or the 74s (which are on thier way out by the way)... it wouldn't surprise me if that was a typo by Panasonic either though. it typically takes them a couple revisions before the info they send out is correct.tomcat57 wrote:Interesting ,
Alex
Don't hold your breath for a picture though, i've already asked and they said they weren't releasing that until the official announcement in April.
Yes It would make sence to stay the same as the cf28/29/30redwoman wrote: Why on earth would they make it a different screen from the touch 52 or the 74s (which are on thier way out by the way)... it wouldn't surprise me if that was a typo by Panasonic either though. it typically takes them a couple revisions before the info they send out is correct.
One improvement would be to use led's for the backlite rather than the ccf tubes that are in use today
The only thing that I don't like too much on my cf-30's in compairison to the cf-29's is that the lid is thicker to allow for the backlites
Even the base thickness could be slimmed down slightly on the new model
I was really wondering / hoping for a slighly larger screen ,14.1" would be nice plus one step up in resolution
As you say the specs are not final, I can always hope
Alex
