FS NIB CF-19 MK-3 MK-4 MK-5 Docking Stations Gamber Johnson
TOUGHNOVIS
#1 Post by TOUGHNOVIS »
These are new in the box Model Number 7160-0264-00 100.00 EA delivered.
I have 4 EA for sale
Antenna Pass-Through: N/A
Weight: 4.15 lbs.
Dimensions: 3.04" H x 11.10" W x 11.67" D
Features:
•Designed using MIL-STD-810F test procedures
•Gamber-Johnson has worked with Panasonic to perform the appropriate tests needed to qualify a product as Toughbook Certified.
•Design works with Toughbook 19 MK4/MK5/MK6 computers only. The CF-19 MK4/MK5/MK6 Toughbook computer will be identified with a letter “R” or higher in the model number (i.e. CF-19R...).
•Can be positioned both vertically (Tablet PC) or horizontal (Notebook PC)
•Push button latching mechanism draws computer down for docking connection
•Internal/protected circuit board protects against dirt and dust
•Brass locating pins for precise computer placement
•Front clips provide computer guidance
•Floating docking connector for reliable docking connection
•Side LED indicator light, shows when the dock has power
•Rounded edges to enhance personal safety
•Use Lind Auto Adapter (Item No. 11798)
•Can be used with any Motion Attachment
•Must be used with Motion Attachment
•Cut out on each side of docking station to allow unrestricted access to adjust the Motion Attachment
•Aluminum structure for reduced overall weight
•Rugged construction for long-term durability
•Black powdercoat finish for maximum corrosion resistance
•3 year limited warranty
Configurable: YES
Panasonic recommends that the CF19 computers should not be “hot docked” into any docking station
MSRP: 1,020
Related Products
