CF-72 cpu upgrade
safn1949
CF-72 cpu upgrade
#1 Post by safn1949 »
So the Pentium 4 CPU is removable in a CF-72......who knew. :D
So my question is how far can I go,the list shows up to 2.6 in the 400 FSB but the multipliers are different,now I did this on a CF-51 1.7 Pentium M where I put a 2.13 Pentium M in it but it showed CPU speed as 1.6. I was told that was due to the different multiplier and never found out how fast it was really going.
Mind you this was 2 years ago. As I have several CF-72's and too much time on my hands,I want to kick it up to 2.6. Now you guys need to tell me why I can't if I can't,never too old to learn. :P
http://en.wikipedia.org/wiki/List_of_In ... processors
Re: CF-72 cpu upgrade
#2 Post by SHEEPMAN! »
Ador is your man. Been a year or so since I did this with CF-51.....up to 7600?????
#3 Post by ADOR »
Back then the 72's and 48's had a removable CPU. I had two Mk1 or Mk3 72's and got rid of them a few years back. I never really got deep into them. What's the full model number so we can figure out the full specs.
Is the heat sink solid copper like on the 51?
I have a lot of the older gaming laptops I collect and when I can find the older CPU's cheap I upgrade. I think the best one is the Voodoo with P4 3.8 extreme, 7800 GTX and dual harddrives in RAID.
I think those units also have ATI graphics so that will help in the power department as well.
#4 Post by ADOR »
Let the research begin. (GIVE ME FUEL, GIVE ME FIRE, GIVE ME THAT WHICH I DESIRE)
Quotes below
http://forum.notebookreview.com/panason ... 1-4-a.html
The CF-72s can be upgraded, but only in the same family, I.E. the 1.6Ghz P4m model will accept up to a 2.5Ghz p4m processor as long as it is a 478 pin .13micron 400mhz front side bus. The Pentium 3m models will take up to around a 1.2Ghz p3m.
So it depends on which processor the CF-48 is actually using and whether they are soldered in.
( I think before that is where you messed up on your speed on your previous swap. If you dropped a 533 MHZ CPU into a motherboard that only supported 400 MHZ speed it will work but will be underclocked)(this can help some on heat running underclocked, but unless your cooling is messed up the Pentium M series runs very cool to begin with and shouldn't really need it)
safn1949
#5 Post by safn1949 »
CF-72VCJUZQM is the one I am putting together from a couple of units,it's interesting in that you split the case and the heatsink and fan are on one half and the motherboard on the other.BRB as I take some photos.These are from the 72X donor with a shorted mobo.
#6 Post by ADOR »
safn1949
#7 Post by safn1949 »
Just picked up a Pentium 4 2.5ghz SL6WY for it,the 2.6 was really expensive for me to just fool around with and I got this one from a buyer I deal with. Should be interesting with over a GB of ram in it and a 7200rpm drive.
#8 Post by ADOR »
That is the reason on the Pentium M's I stick with the 2.0 and some times the 2.1. I can get those for around 20 bucks, it jumps to 80 plus for the 2.2.
safn1949
#9 Post by safn1949 »
Got the 2.5 for $23,he has one more if you want it.
#10 Post by ADOR »
I don't have anything right now that needs it, but thanks anyway. ( I am on some desktop projects right now)
