Any special order to install drivers
#1 Post by toughasnails »
I was just wondering if their was any special order to install the drivers. My last CF-29C 1.2 I had the MK1 disk but this one is a CF-29H 1.4 MK3. I loaded XP Pro and the touchscreen then all the drivers but lost the touchscreen some where when I finished. Just going to start over and wanted to check first.
tomcat57
Re: Any special order to install drivers
#2 Post by tomcat57 »
I don't have enough experiance on this
I usualy have the restore
But heres what I would do
Windows inc sp3
Chipset driver for the motherboard
Video if needed ,then sound
Then wireless switch if there is one,the wired lan should be loaded from windows
Updated driver for wi-fi
Hot key stuff
Last is the touchscreen
Alex
#3 Post by toughasnails »
That's the way I figured I would do it this time just figured I would ask. BTW thanks 4 the help on the 18 .It been running straight for 2 days. Saturday went away , plugged in the gps and it run no problem at all , no errors......sweet :pbjt:
#4 Post by toughasnails »
Well that was fun. After loading XP Pro + the drivers 5 times I got it. I will post later the order I installed them in
liamw652
#5 Post by liamw652 »
toughasnails wrote:Well that was fun. After loading XP Pro + the drivers 5 times I got it. I will post later the order I installed them in
The last time I was on the Panny site, downloading all the drivers for my J model (for archive) there was a .pdf file listed called SOFT FIRST. Reading this .pdf file, it told me the exact order to install and how to intall. It told the whole route, from the compressed self extracting .exe, to the Util2 Directory. Then from there through .exe install or system devices.
It explained the UNKNOWN DEVICE and every step to correctly install everything.
If you need this I will be happy to send it to you. Let me know. I also attached it.
soft_first.pdf
(60 KiB) Downloaded 819 times
Bill
CF-29 M Touch
CF-30 Mk1 Touch
CF-19 Mk3 Touch
#6 Post by toughasnails »
Thank you , had it at one time just not sure where I put it
