WTB HDD, caddy and Win XP Pro for a CF-T5
zedulon
#1 Post by zedulon »
I have a very nice CF-T5 MWETZBM that I would like to get back into stock/factory specs. It came to me without the HDD and software. First time posting, so please be gentle. Thanks!
God, Grant me the serenity to accept the things I can not change, the courage to change the things I can, and the wisdom to know the difference.
Re: WTB HDD, caddy and Win XP Pro for a CF-T5
#2 Post by toughasnails »
Welcome to Toughbook Talk
Hopefully someone will be able to help you out.
Below is what your Toughbook had when it left the factory
Model Number : CF-T5MWETZBM (MK3)
Status : DISCONTINUED
MSRP : $2,099
Description: Intel Core Duo Processor ULV U2400 1.06Ghz (Centrino), 12.1" Touch XGA, 512MB, 60GB, Intel 802.11a+b+g, WinXP Pro SP2, TPM1.2, No Optical
#3 Post by teo »
T5? This machine has IDE harddrive not SATA(2.5" IDE harddrive to be exact). Did the hdd cable ribbon still there?
safn1949
#4 Post by safn1949 »
There is really nothing to the caddy,a plastic sleeve and foam,I would just use a couple of strips of padded foam and any ide drive and you will be in business.
Is the bottom cover there? If not that's a different story.Got to have that cover.
#5 Post by ADOR »
He is correct, not much to it. It's the same thing for the T5,7,8 and the W and Y models. Just a little foam. The T5 will be fanless, but also uses a Micro RAM. If you decide you like that model and want a newer one. Look for a T8. That would give you SATA hookup for the hard drive, It has a fan, uses standard size ram and LED screen.
#6 Post by Springfield »
I have a few scrap T5's and parts, and I'm in Central Florida not to far away. Send me a Private Message (pm) and we can work the details.
-Ken in Orlando
zedulon
#7 Post by zedulon »
Thanks for the replies, y'all. I have not cracked the case on the T5 yet. Its hard drive was replaced with a 60GB solid state module; running Xubuntu 14.04.
I got a 64GB SDHC dedicated to this machine for data files. Works nicely.
Maybe I should leave this little hot-rod alone....
Springfield wrote:I have a few scrap T5's and parts, and I'm in Central Florida not to far away. Send me a Private Message (pm) and we can work the details.
-Ken in Orlando
Ken, I can't PM yet. do ya have any 1 GB RAM modules?
#8 Post by toughasnails »
Yes you can PM. On NBR you need 5 post but not here....you are good to go
#9 Post by Springfield »
zedulon wrote:Ken, I can't PM yet. do ya have any 1 GB RAM modules?
Not 1 GB but do have a 512MB ram for it.
$2 for postage and its yours.
#10 Post by SHEEPMAN! »
If you want a twin to your unit I have one. :D Toshiba MK6034GAX drive /Zorin OS.
Three or four bright spots in the screen. Otherwise nice. Has a strap and stylus. Excellent battery. XP COA.
Welcome to the party.
