I just found this forum after trawling online for info on Toughbooks (Thanks for the registration approval, Robert
So all is good, everything works as it should - except the optical drive. I've removed it and re-seated it and it clicks solidly into place and as I said, seems to spin up and has power going to it but it plain refuses to show up in the BIOS or Windows. During the re-install of the OS, when applying Windows Updates at one point I'm sure it actually did show up under 'My Computer' as some sort of generic DVD drive but then after restarting the PC to apply further updates, when it rebooted the DVD drive icon had vanished again. No idea why and previous to it vanishing I'm unsure whether it actually appeared in the BIOS or not.
So, would appreciate some advice on what to try next. Is there anything I can do to get it working, could it be a loose connection inside on the motherboard or something?
Many thanks in advance for any info!
