CF-U1 Mk2 Service Manual
Hello,
Does anybody know if it exists a disassembly guide for the CF-U1, I have some disassembly guides for the CF-19 but I haven't be able to find the guide for the CF-U1.
Regards.
Re: CF-U1 Mk2 Service Manual
I have to do this too before long. Taking a upgraded Mk2 that looks rough with a busted screen and hoping to drop it into one of the Mk1 bodies I have.
This is what I could dug up real quick.
http://www.chipworks.com/en/technical-c ... toughbook/
http://www.custom-toughbooks.com/index. ... cts_id=195
When I get a chance I will look though my saved files to see if I have anything else.
Thanks ADOR, I'd already seen that sites.
I spent a few hours trying and find the disassembly manual, unfortunately, it seems Panasonic has this manual kept on a safe.
I'd really like to see how this little beast is disassembled.
Regards.
I will post something to dropbox...
here you go kids....
https://www.dropbox.com/s/pmyz3tjgwx1tw ... e.zip?dl=0
Mr. Phelps....This file will self destruct in 7 days..
Shawn, you're my hero.
I thought I was going to die without knowing how to open it.
P.S: The document is amazing, it's probably the best one I've never seen. THANK YOU!
Regards.
File 404 not foundShawn wrote:here you go kids....
I wanted to put it on the downloads site
Rob, Can I ask what the download sites are and where I can find it?
Regards.
WittgensteinSergeant
public_downloadsrrtek wrote:Rob, Can I ask what the download sites are and where I can find it?
