Starting here . Need a CF-52 Caddy and a large platter drive. 7200 rpm?
Checking ebray next.
WANTED CF-52 CADDY / DRIVE?
Re: WANTED CF-52 CADDY / DRIVE?
320 would be fine. They got cheap.
Prefer getting one here as I assume they have been tested.
Better yet I will be needing a second drive. This one 52 ended up missing a caddy/drive and the Fraulein wants to upgrade her GUN to 7.
So yeah,
1 caddy at least.
2 drives...320 or?
Anybody need a CF-T5?
So yeah,
1 caddy at least.
2 drives...320 or?
I got rid of the 320 I had...Bought a refurbed 1tb to replace it...
I have a 500 (maybe 2 of them) that is 12mm....need to use an alternative foam for it to fit in a 52...I had in a 52 I just shipped
Sticky sided alternative foam is still attached to the drive....It's loaded with fresh Win7 recovery for a CF52G...
I doubt that it's what you are looking for.
Confused....what size drive is in the one you shipped? You have one or two? You haven't shipped anything here for a while.
That is exactly what I am looking for...now that you brought it up.
I have a Seagate Momentus 7200.4 500GB that you can have, and if you want I can install a 52MK2 factory restore for W7 on it. Can ship Monday.
Dandy. PM sent.
Dinner awaits.
Swiss Chard, mustard greens and bacon.
TTYT
J'd
Dinner awaits.
TTYT
J'd
