Battery Recallibration Program
- twillingham
I cant seem to locate the program can anyone help
- Silver Trooper
Re: Battery Recallibration Program
I am at work right now, but if memory serves me correct, it should be in the listed Panny programs under all programs. If not there, you may still have to download from the Panny site. What model TB do you have?
- twillingham
CF-73 I cant find the program for the MK1 Everyone I attempt to download it says not for this machine. What is your thought on this. I think my battery needs callibrating because it will run for two hours but after one hour I get the warning that I need to plug it in. I never have to plug it in and it still runs an additional hour for a total of two I wonder why does it say its at a critical point but then runs for an additional hour. Does this battery need callibrating or some of the cells are dead and I need to replace it
- twillingham
BTW which panasonic site are you referring
- twillingham
I found my answer. ON this model of the 73 The battery recallibration utility is in the F2 bios menu.
