upgrading ut-mb5
Post all questions and information about the 20" 4K Windows tablet in here.
Reckless
upgrading ut-mb5
#1 Post by Reckless »
One of my ut-mb5's is a pre-production unit and only has 4gb ram. I want to upgrade it to 8 or more does anyone know why that might not work?
ut-mb5 inside.JPG (46.19 KiB) Viewed 19210 times
Toughbook Collection:
RZ4, NX2, NX, AX2, B11, B10, N10, N8, W4, T5, T4, T2, T1, Y4, S4, R1, R9
(Direct from the Land of the Rising Sun)
ToughPad Collection:
MB5 4k, MB5 4k Prototype
Touch Monitors & Displays:
Pixelsense: Microsoft Surface 2.0 Tables
Sharp Interactive Aquos Board 70"
Re: upgrading ut-mb5
#2 Post by Rob »
That pic is too small to see any detail but it appears to have a normal laptop chip in there. Just match the spex on it and pop an 8GB one in there.
Reckless
#3 Post by Reckless »
Do you think 16GB might work? Sorry I will upload a better image later (been extremely busy with work).
#4 Post by Rob »
Uhhhhggggg..... Doubt it.
Can you do me a favor?
Run CPU-Z (http://www.cpuid.com/softwares/cpu-z/ve ... story.html) and give me the report on the motherboard? I wanna cross reference the chipset!
Reckless
#5 Post by Reckless »
This unit is a pre-production unit, not sure if that has any impact
UT-MB.txt
(81.97 KiB) Downloaded 941 times
#6 Post by Rob »
After analyzing that it would APPEAR that it SHOULD work with a 16GB chip...
http://ark.intel.com/products/71259/Int ... Hz?q=3437U - This shows 32GB max which would mean 2 x 16GB chips
Also, in the report I see:
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 32768 MBytes
max# of devices 2
DMI Memory Device
designation ChannelA-DIMM0
format DIMM
type unknown
DMI Memory Device
designation ChannelB-DIMM0
format SODIMM
type unknown
total width 64 bits
data width 64 bits
size 4096 MBytes
Can you confirm that there are 2 RAM slots or is there only 1?
Reckless
#7 Post by Reckless »
i have higher resolution photo attached but i believe its only one (didnt check carefully enough). I bought a 8gb sim from frys but I think I should have bought 16gb. What do you think?
#8 Post by Rob »
Naw,
Looks like 1 slot for sure. Worst case the other slot (If it had it) would be on the other side.
Did the 8GB one work ok?
Reckless
#9 Post by Reckless »
I haven't tried it. I was debating about putting 16GB in it and then I just got a call from Panasonic parts dept saying only 8 GB will fit.
I am debating about wasting the time to go to fry's buy 16gb and trying it before putting the 8 gb in. The parts store said the largest hard drive that will fit is 256gb but I put a 1 TB inside. The machine does not have good heat ventilation but my understanding is that performance Samsung drives tend to be cooler than mainstream hard drives.
Reckless
#10 Post by Reckless »
I havent found a 16gb chip at Frys. I wonder if anyone makes one? It seems that people put 8gb x 4.
Return to “UT-MB5 / FZ-Y1 20" 4K Toughpad Talk (Discontinued Models)”
