So I bought a Mk-3, plan is to swap all my Mk-2 stuff in it- SSD/Caddy, memory, battery, and whatever else I can use. Then sell this excellent condition Mk-2 to recoup some funds. your thoughts??
this is the model- CF-30KCPAX2M
found a bone stock Mk-3, can I swap my MK-2 stuff into it?
CF-C2AKFZGLM My newest one
Re: found a bone stock Mk-3, can I swap my MK-2 stuff into i
Model Number : CF-30KCPAX2M
Status : DISCONTINUED
MSRP : $2,200
Description: WinXP (Vista COA), Intel Core 2 Duo SL9300 1.60GHz (Centrino2), vPro, 13.3" XGA Touch, 160GB, 2GB, Intel WiFi a/b/g/n, TPM1.2, Bluetooth, Dual Pass (Upper:WWAN/Lower:WLAN), Emissive Backlit Keyboard, No Drive, Toughbook Preferred
That's what I would do. Maybe even keep an eye out for a cheap caddy...would sell faster that way.
MSRP : $2,200
Sweet. Would I have to reinstall Windows due to the new computer?
Win 7 should adjust and make the needed changes. You will have to activate Win 7 again.
Shawn wrote:Win 7 should adjust and make the needed changes. You will have to activate Win 7 again.
Thats great! now need to find the HD caddy. will one off a CF-29 work? are there any others that are compatible??
CF29 is different
Cf30 and CF31 are the only ones that will work
OK Thanks for the info
this boots up just fine, but BIOS password protected. If anyone needs parts let me know or you can buy the whole thing... no battery, HDD/caddy, powercords...
