So which is a better / faster OS 32bit or 64bit ??
#1 Post by toughasnails »
email address is nicks@nb.sympatico.ca
So which is better and faster...W7 32bit or W7 64bit ?? Now the 52 shows 8GB memory but as we all know it only uses 3.2GB where the 53 uses all it's 16GB installed memory. The 52 has the better video card, AMD Radeon HD 6750M and the 53 has the Intel HD Graphics. So the extra cost of the memory which will set you back about $150.00-$200.00...is it really worth it to go with 64Bit. Check out my results below
CF-52 CF-53 A.jpg (188.01 KiB) Viewed 13163 times
Re: So which is a better / faster OS 32bit or 64bit ??
That's what I have been saying all along....Unless you are running very specific types of programs...64bit and all the memory that is needed is a waste of money....
#3 Post by ADOR »
Most gaming setups they recommend 8gb. just go for the fastest speed for your system. You will see some interesting things with the uo coming ddr4 ram and am d's apu.
