It is currently Fri Feb 15, 2019 3:53 pm
 Post subject: c1 mk2
PostPosted: Tue Jul 15, 2014 6:36 pm
ok ive just acquired a c2 mk2...couple questions...
1. I keep finding and loosing the configurator can someone lend some info cf-c1bdhdz1m....
2. The web cam didn't work when I got it(seller knew it didn't) but it was off in bios...ive enabled it and re tried installing the driver for it with no luck... I have in device manager unknown device that wont reset no mater what ive tried.....
 Post subject: Re: c1 mk2
PostPosted: Tue Jul 15, 2014 7:18 pm
see http://www.panasonic.com/business/Tough ... puters.asp
Quote:
Model Number: CF-C1BDHDZ1M
Status: DISCONTINUED
MSRP: $3,010
Description: Win7, Intel Core i5-2520M 2.50GHz, vPro, 12.1" WXGA Multi Touch+Digitizer, 320GB(7200rpm), 4GB, Intel WiFi a/b/g/n, TPM, Bluetooth, 56k modem (RJ11), Webcam, Smartcard, Fingerprint, No Drive, Toughbook Preferred
PostPosted: Sat Jul 19, 2014 7:38 am
Thanks Springfield!
PostPosted: Sat Jul 26, 2014 7:05 pm
Ok, update....there's one usb port on the left side that doesn't work the device powers up but nothing on the computer, so I went into device manager and the unknown device is gone. Unplug usb and unknown device is back....any thoughts?
