I bought some DS-PAN-201 CF-19 docks in nice shape but without the mounting plate on the bottom. What I need are pictures of the mounting plate on the bottom. A forum member has the same dock and said he would take some pictures of the mounting plate but has been busy. I am hoping that there are other members that have the same dock and can take some pictures of the mounting plate for me. I am most interested in the area that the power adapter is mounted. I want to make sure there will be enough room to mount the adapters.
Any help is appreciated. Thanks.
Re: DS-PAN-201 CF-19 dock
I can get this.
Hang tight.
Hang tight.
Here is what I got back from Havis:
Sure – the mounting bracket for the dock is D8-0062-SM (That is $49). There should be enough room next to the bracket to put the LPS-101 power supply underneath as recommended. (Bracket shown in installation instructions here: http://www.havis.com/data/2-Computing/D ... T_6-10.pdf )
Awesome Rob! Thank you!
It is basically like I thought it would be, but good to see exactly how it is formed.
