usb ports
Re: usb ports
It seems like the usb pcb is or has failed part number DF36U1540GAA. May be some one here has one...could not find one on the bay.
-Nick
-Nick
- DF36U1540GAA.jpg (1.45 KiB) Viewed 26518 times
Re: usb ports
hmm...it was weird its out of the blue but it is what it is i guess...lol thanks... im going to try to get a hold of our IT guy at work maybe he has some canalized ones....but theres no telling..
EdFromBJCS
Re: usb ports
If your IT guy doesn't have one, we have one at http://bobjohnson.com/_store/Display_Pr ... 40WA-2%2E0 for about $60. Feel free to call us if you have any questions. Our tech Marisa would be a good person to talk to.
Re: usb ports
Anyone know if all the CF-30s use the ssame usb board? my it guy has some out of the mk1's cf-30cxxxxx's
Re: usb ports
I had one in a CF-30MK1 do the same. The picture that i58sr posted looks the same as the one I replaced. My guess is that they are the same.
Re: usb ports
my guess to but ive never been in a 30...only several 29's lol....my IT guy says hes got several donor ones he can send me....hope they work!
EdFromBJCS
Re: usb ports
Yes. All the CF-30s use the same USB board.Mxx20 wrote:Anyone know if all the CF-30s use the ssame usb board? my it guy has some out of the mk1's cf-30cxxxxx's
Re: usb ports
Awesome, my IT guy says he's going to send one...but now the waiting game lol
Re: usb ports
that's a good MB design in toughbooks - having daughterboards for external ports like USB, that may be subject to physical/electrical damage, for an easy/cheap replacement.
you wouldn't want to replace the whole MB for that.
C1mk1&2, CF19mk4, CF30mk1&mk3
