OT Extension Lead for Touch Panel OT
Working on a Autel Automotive scanner and the Universal Touch Panel Lead (FPC) is about an inch too short. Does anyone know of a source for an extension? I'd send the 7" panel back but shipping is prohibitive time wise.
This FPC looks exactly like a connector on a Panasonic Touch Panel.
I'm searching but having terminology issues. I saw one a couple years ago a friend was using on a CF-19 China panel. I have room to stuff any spare cabling. IOW 4 to 6 inches would work.
Re: OT Extension Lead for Touch Panel OT
photo of cable?
dimensions?
number of pins?
writing on cable?
need to figure out pitch(distance between pins)
I have a small assortment of extended length cables
here's an example of an extension cable male to female
http://www.ebay.com/itm/4P-FFC-Extensio ... 1c3d85c8be
dimensions?
number of pins?
writing on cable?
Shawn,
271016864464 (ebay number)
Dimensions are on the blue print. Where it says cable length 40...I have 32 on the one I got. I need 1/2 inch of slack unless I have to turn the cable upside down. Then a bit more.
Thought of trimming a slot in the mobo but that could get expensive if I hit a buried trace.
I'm not good at terminology but if it fits the four lead connector on a TSPCB it is correct. The Autel TS/LCD uses the slidie connector like a CF-19 not the springie one like a CF-29. (slidie and springie are technobabble) sic
http://www.youtube.com/watch?v=e3IaI1yMvPk (lousy music to my ears)
The one i linked to is the same size and number of pins. It "should" work.
1.0mm pitch 4pins
alternatives
http://kyorune.com/modding/article.php?id=63
Toughbook(Rick) could probably solder a fpc cable directly to the short one.
1.0mm pitch 4pins
alternatives
Found one answer.
4 x 1mm standard fpc cable. Whatever a mm is.
I see the problem. You forgot the '&'. M&M
You know.
I need the green thing...wrote to zahar1968 to see if he remembered where he got this. Stole his image while I was at it. (Thank you Slava for use of your picture)
- P1010234.JPG (20.1 KiB) Viewed 17514 times
I did some quick checking for one of those. I couldn't find the correct size..I was kinda tired and my head was throbbing.( week 2 or 3 of head throbbing)
MMMMMM chocolate covered peanuts....
1mm equals 28.57 medium crossbred sheep hairs (35 microns each)
See, nothing hard about metric.
Looks like Shawn got his Metric PHD and didn't mention it, until now.
And if I had a green thingy, I would go to the docs and get a shot to clear that up!
That's about all the help I can offer.
Unless you're a Martianmklym wrote:...
And if I had a green thingy, I would go to the docs and get a shot to clear that up!![]()
