Custom TOughbook Badges
j0llyr0ger
#1 Post by j0llyr0ger »
So I made a custom TB badge to replace them on my TBs and posted it up on NBR and there was some interest so I'll post em' here!
I am a laser engraver, and can cut and engrave a lot of stuff.
anyhow, if anyone wants one, let me know what graphic you want/color, etc.
Re: Custom TOughbook Badges
#2 Post by toughasnails »
Here is a picture of one of mine, will update it when I get the other one in
new badge 2.jpg (39.5 KiB) Viewed 26262 times
mklym
#3 Post by mklym »
I'd imagine that doing reproductions of the factory label would be no problem? Black letters on silver background, textured if possible. Ball park price on a lot of 10? Time frame from payment until shipped? You can reply here or by PM. Thank you.
j0llyr0ger
#4 Post by j0llyr0ger »
Thanks! I'll pM you when I find a suitable material to match the factory config closely.
However on mine, the letters seem to be raised silver. are there different revisions?
Can you send me an example photo?
I usu charge 20 ea shipped for custom ones, but if you're ordering a bunch and they are all the same and a simple design they should be much much cheaper.
mklym
#5 Post by mklym »
Okay, I'll look for a pic. Thanks.
mklym
#6 Post by mklym »
Here is an example.
j0llyr0ger
#7 Post by j0llyr0ger »
out of curiosity, why would one need these? Just restoration? I mean they don't come off all that easy.
mklym
#8 Post by mklym »
I have been waiting for 2 months for labels from Panasonic to finish off some units I am waiting to sell. A couple units have no label and the others have labels that are not as nice as the rest of the units they are on. I can probably get your laser cut ones, install them and have the units sold before the labels show up from Panasonic. Other than that, no reason I can think of. :D
#9 Post by SHEEPMAN! »
j0llyr0ger wrote:out of curiosity, why would one need these? Just restoration? I mean they don't come off all that easy.
Sorta like the baby moon hub caps and black wheels on my '61 Falcon...or the chrome wheels on my F-350. Eye candy.
#10 Post by teo »
Do you have any Balckhawk, Black Widow and how about yours Jef! Black Scorpion, Lol.. j/k. Mine will be Black is Black, lol..There a lot now on EBAY with Black.
Anyway, I will design my own logo first and then send it to you Jolly or a simple one. The OEM with added black trim all around its side about 3mm distance.
