Run Mint 16 with the following:
Install updates and upgrades after initial install.
For the Touchscreen:
sudo mkdir /etc/X11/xorg.conf.dSuper Key type syn [enter]
From Synaptics package manager install xinput-calibrate.
Super Key type cali [enter]
Touch the x'es.
In the terminal you left open:
sudo gedit /etc/X11/xorg.conf.d/99-calibration.confClose terminals and editor. You are supposed to have all three open at one time.
You are now calibrated and 99-calibration file will be read each time machine boots.
The 53 needed no other tweaks. If gedit is missing from any distro I:
sudo apt-get install geditnote: Super key is between [Fn] and [Alt]
