I just found this on the Yahoo Toughbook Forum. This guy has done a lot of mods to his M34 and he has a great pdf covering it. You should check it out...
http://f1.grp.yahoofs.com/v2/QIzCUjQzni ... Book-4.pdf
Looking to Mod your CF-M34 ?
Re: Looking to Mod your CF-M34 ?
I will have to look at the group and see if I can get a copy. I couldn't get your link to work.
Ok I fixed the link...I think. Click on Tougbook and go to files then at almost the bottom click Labels for modifications to 1GHz CFM-34 ToughBook-4.pdf CFM-34 1GHz CPU model modifications
and the download should start
To get this you must log in to yahoo groups
Link no worky...
Document Not Found
The document you requested could not be found.
Document Not Found
I went to the group there as I am a member and got the file. I know you use to beable to hot link the download. I haven't tried it since yahoo swapped the mail and other stuff on the groups. Maybe they changed it.
Let me see if this upload will work.
- Labels for modifications to 1GHz CFM-34 ToughBook-4.pdf
- (379.63 KiB) Downloaded 1167 times
WOW! Looks cool!!!!!!!!!!!!!
How about we put this here Rob http://www.toughbooktalk.com/public_downloads/
DONE: http://www.toughbooktalk.com/public_dow ... 4%20Stuff/toughasnails wrote:How about we put this here Rob http://www.toughbooktalk.com/public_downloads/
