Today I have a used, Scratch and Dent, Mark 6, Panasonic Toughbook (1330 Hours),Model Number CF-191HYAV1M...This is a Touchscreen Machine that features the Windows 7 Professional 32 bit (Recovery partition will install 64 bit) Operating System,an Intel i5 3320M Processor running 2 cores at 2.6 Ghz,Intel HD 4000 Graphics, a 500Gig Hard Drive,Standard Keyboard, 4 Gigs of Ram, Battery, Handstrap,Stylus, Oem Ac Adapter, Verizon 4g LTE (Sim Card Required) and Stand Alone Gps. I have installed and configured Streets and Trips 2010 and the machine is ready to go out of the box. I will send it out fully charged but I DO NOT have a charger for these machines so none will be included. This is a great machine that performs like new.This is the latest model CF-19!
I actually have two of these...the other one only has on major scuff and only 450 hours. Same price, the nicer one will ship first...Feel free to call or message me here, Travis 828 734 eighteen seventy seven
The case is as pictured with a few scuffs that do not affect the functionality of the machine. The Screensaver covers a Clean and Bright Display. Below are the Quick Specs followed by the detailed ones...
Model Number:
CF-191HYAV1M
Status:
CURRENT
MSRP:
$4,009
Description: Windows 7 Professional, Intel Core i5‑3320M 2.60GHz, 10.1" XGA Touchscreen LCD, 500GB Shock‑mounted HDD (7200rpm), 4GB, Wi‑Fi, Bluetooth, 4G Verizon LTE, Dual Pass (Upper WWAN / Lower Wi‑Fi), Modem, TPM 1.2, Toughbook Preferred
Please feel free to message or call with any questions you may have and thank you for your interest.
828 734 1877
Cache 3 MB
Processor Core Dual-core 2 Core
Green Compliant Yes
Green Compliance Certificate/authority EPEAT Gold
Memory Card Reader Yes
Hard Drive Capacity 500 GB
Battery Capacity 5600 mAh
Touchscreen Yes
64-bit Processing Yes
Processor Manufacturer Intel
Chipset Manufacturer Intel
Chipset Model QM67 Express
Graphics Controller Manufacturer Intel
Graphics Controller Model HD 4000
Bluetooth Yes
Wi-fi Yes
Optical Drive Type No
Graphics Memory Technology DDR3 SDRAM
Graphics Memory Accessibility Shared
Maximum Battery Run Time 9 Hour
Display Screen Type Active Matrix TFT Color LCD
Display Screen Technology CircuLumin
Hard Drive Rpm 7200
Wi-fi Manufacturer Intel
Wi-fi Model Centrino Advanced-N 6205
Wwan Supported Yes
Wi-fi Standard IEEE 802.11a/b/g/n
Bluetooth Standard Bluetooth 2.1
Hyper-threading Yes
Vpro Technology Yes
Ethernet Technology Gigabit Ethernet
Construction Rugged
Firewire/i.link Yes
Backlight Technology LED
Vga Yes
Network rj-45 Yes
Audio Line In Yes
Audio Line Out Yes
Modem rj-11 Yes
Cellular Data Connectivity Technology LTE
Direct Media Interface 5 GT/s
Total Number Of Usb Ports 2
Number Of Usb 2.0 Ports 2
Memory Card Supported Secure Digital Extended Capacity SDXC
Processor Model i5-3320M
Memory Standard DDR3-1333/PC3-10600
Height 1.9"
Width 10.7"
Depth 8.5"
Expansion Slot Type ExpressCard/54
Screen Mode XGA
Operating System Genuine Windows 7 Professional
Certifications & Standards ACPIMIL-STD-810GIP65 CertifiedSection 508 Standards
Color Supported 16.7 Million Colors
Product Series 19
Keyboard Yes
Manufacturer Panasonic
Product Model CF-191HYAV1M
Modem Yes
Pointing Device Type Stylus
Processor Speed 2.60 GHz
Processor Type Core i5
Product Line Toughbook
Screen Size 10.1"
Security Features Kensington Cable Lock SlotTrusted Platform Module TPM Security Chip v.1.2Computrace Theft Protection Agent in BIOSIntel Anti-Theft TechnologyPassword Security:SupervisorUserHard Disk Lock
Aspect Ratio 4:3
Input Voltage 220 V AC
Manufacturer Part Number CF-191HYAV1M
Maximum Memory 8 GB
Battery Chemistry Lithium Ion Li-Ion
Package Contents Toughbook CF-191HYAV1M NotebookLithium Ion BatteryAC AdapterStylus
Screen Resolution 1024 x 768
Speakers Yes
Software Included Panasonic UtilitiesPanasonic DashboardRecovery Partition
Standard Memory 4 GB
Weight approximate 5.10 lb
CF-191HYAV1M $1600.00 through paypal Scratch and Dent...
almstprfct1
- DSCN2014.JPG (32.5 KiB) Viewed 13358 times
- DSCN2011.JPG (75.54 KiB) Viewed 13358 times
- DSCN2010.JPG (78.88 KiB) Viewed 13358 times
- DSCN2009.JPG (63.07 KiB) Viewed 13358 times
- DSCN2008.JPG (80.5 KiB) Viewed 13358 times
Re: CF-191HYAV1M $1600.00 through paypal Scratch and Dent...
Are you kidding? Resize your pictures or use links. Those are ridicules.
WHOAH!!!!! I've resized them!
Travis, remember to make sure the images are no bigger than 800x600 next time!
On a side note: Travis is a stand up guy! I've worked with him for YEARS now! He is VERY reputable and trustworthy too! Don't ever have to worry about doing business with him!
Rob,
Thanks for the resize and the background info on the OP. Much appreciated.
