CF-52 Models
CF-52 Models
#1 Post by toughasnails »
This is a list of some of the models of the CF-52...still working on it. If anyone has a model not listed post what you have and I will add it to this list
CF-52 MODELS
MK1
CORE 2 DUO T7100 @ 1.8GHz
Core 2 Duo @ 2.0GHz
MK2
CORE 2 DUO P8400 @ 2.26GHz
CORE 2 DUO P8600 @ 2.4GHz
MK3
Intel Core i3 M330 2.13GHz
Intel Core i5 M520 2.40GHz
Intel Core i5 M540 2.53GHz
MK4
Core i5 - 2540M 2.60GHz
Core i5 - 3360M 2.80GHz
Gear6
Re: CF-52 Models
#2 Post by Gear6 »
isn't the Mk3 M520 an i5 rather than i3 ?
C1mk1&2, CF19mk4, CF30mk1&mk3
Re: CF-52 Models
#3 Post by Shawn »
If we're starting a FAQ..
I believe the i3 and i5 models have a SATA media bay and not IDE like all the rest
Re: CF-52 Models
#4 Post by toughasnails »
Gear6 wrote:isn't the Mk3 M520 an i5 rather than i3 ?
Yes it is , my eyes were playing tricks on me ;)
d9e5v4
Re: CF-52 Models
#5 Post by d9e5v4 »
The Core i5 - 2540M 2.60GHz is a MK4 and the Core i5 - 3360M 2.80GHz is a MK5. That's the way it is on the panasonic d/l page and that explains why the 2.6 is a 2nd gen i5 and the 2.8 is a 3rd. Not trying to sound rude, just thinking out loud. That always confused me but it just clicked.
Re: CF-52 Models
#6 Post by ADOR »
Let me dig out the info I had put up for a thread for this put up. Just haven't had time to research the newer models.
Re: CF-52 Models
#7 Post by ADOR »
Mark 1 (High End) -- CF-52A/B
Mark 1 (Low End) -- CF-52C/D
PC cards
One Type II PC card and one PC express card
Sound Card
CF-52A/B (Mk1 High End) Intel High Definition Audio Complaint
CF-52C/D (Mk1 Low End) Intel High Definition Audio Complaint
Video Card
CF-52A/B (Mk1 High End) ATI HD2300 512 MB
CF-52C/D (Mk1 Low End) Intel GMA x3100 UMA up to 128MB/384MB (WXGA)
CPU (non removable)
CF-52A/B (Mk1 High End) -- Intel Core 2 Duo T7300 2.0GHz
CF-52C/D (Mk1 Low End) -- Intel Core 2 Duo T7100 1.8GHz
Memory (RAM)
CF-52A/B (Mk1 High End) Expandable to 4,096 MB
CF-52C/D (Mk1 Low End) Expandable to 4,096 MB
CF-52A/B (Mk1 High End) -- DDR2 SDRAM, PC2-5300
CF-52C/D (Mk1 Low End) -- DDR2 SDRAM, PC2-5300
WiFi Card (if equipped)
CF-52A (Mk1 High End) Intel 4965 AGN (802.11 a/b/g)
CF-52C (Mk1 Low End) Intel 4965 AGN (802.11 a/b/g)
Chipset
CF-52A/B (Mk1 High End) -- Mobile Intel PM965
CF-52C/D (Mk1 Low End) -- Mobile Intel GM965
Front Side Bus
CF-52A/B (Mk1 High End) -- 800 MHz
CF-52C/D (Mk1 Low End) -- 800 MHz
Lan
CF-52A/B (Mk1 High End) -- Intel 82566MM Gigabit Network
CF-52C/D (Mk1 Low End) -- Intel 82566MM Gigabit Network
That's the basics for the Mk1, let me find the rest of the Info I had put up.
Re: CF-52 Models
#8 Post by ADOR »
This should save you some typing, mk1/2 models.
CF-52
MK1/2
CPU
A: CORE 2 DUO T7300 2.0 GHZ / 802.11a/b/g
B: CORE 2 DUO T7300 2.0 GHZ / (FEDERAL ONLY, NO WIRELESS)
C: CORE 2 DUO T7100 1.8 GHZ / 802.11a/b/g
D: CORE 2 DUO T7100 1.8 GHZ / (FEDERAL ONLY, NO WIRELESS)
E: CORE 2 DUO P8600 2.4 GHZ / 802.11a/b/g/draft n
F: CORE 2 DUO P8600 2.4 GHZ / (FEDERAL ONLY, NO WIRELESS)
G: CORE 2 DUO P8400 2.26 GHZ / 802.11a/b/g/draft n
H: CORE 2 DUO P8400 2.26 GHZ / (FEDERAL ONLY, NO WIRELESS)
LCD
C: 15.4” WXGA
F: 15.4” WXGA + vPro
G: 15.4” WXGA + vPro + LIGHT BATT + NO RJ-11 + NO FIREWIRE + NO AR
J: 15.4” WUXGA ( 512 MB DEDICATED VIDEO RAM )
K: 15.4” WUXGA ( 512 MB DEDICATED VIDEO RAM )
L: 15.4” WUXGA ( 512 MB DEDICATED VIDEO RAM ) + vPro
U: 13.3” XGA TOUCHSCREEN + vPro
HARD DRIVE / RAM
A: 80 GB HDD AND 1 GB RAM
C: 120 GB HDD AND 1 GB RAM
H: 120 GB HDD AND 2 GB RAM
J: 120 GB HDD AND 4 GB RAM (2 + 2)
L: 160 GB HDD AND 8 GB RAM (4 + 4)
M: 160 GB HDD AND 1 GB RAM
N: 160 GB HDD AND 2 GB RAM
P: 160 GB HDD AND 4 GB RAM (2 + 2)
Q: 160 GB HDD AND 4 GB RAM
R: 160 GB HDD AND 2 GB RAM (1 + 1)
INTERGRATED OPTIONS
B: DVD MULTI-DRIVE
D: DVD MULTI-DRIVE + SMART CARD
F: DVD MULTI-DRIVE + FINGERPRINT
H: DVD MULTI-DRIVE + SMART CARD + FINGERPRINT
1: DVD MULTI-DRIVE + SMART CARD + NO ABSOLUTE IN BIOS
2: DVD MULTI-DRIVE + NO ABSOLUTE IN BIOS
5: DVD MULTI-DRIVE + FINGERPRINT
WIRELESS
A: VERIZON EV-DO (REV A)
B: SPRINT EV-DO (REV A)
C: HSDPA 3.6
D: BLUETOOTH ONLY
E: BLUETOOTH ONLY
F: VERIZON EV-DO (REV A) + BLUETOOTH
G: SPRINT EV-DO (REV A) + BLUETOOTH
H: HSDPA 3.6 + BLUETOOTH
K: VERIZON EV-DO (REV A) + BLUETOOTH
M: HSDPA + BLUETOOTH
P: GOBI
Q: GOBI + BLUETOOTH (PREMIUM MODEL)
R: GOBI + BLUETOOTH (VALUE MODEL)
X: WIRELESS READY
Z: NO WIRELESS
0: NO WIRELESS AND NO ABSOLUTE IN BIOS
7: GOBI + BLUETOOTH
OPERATING SYSTEM
A: WINDOWS VISTA COA, DOWNGRADE TO XP
B: WINDOWS XP
J: WINDOWS VISTA
1: WINDOWS VISTA + TOUGHBOOK PREFERRED
2: WINDOWS VISTA COA, XP DOWNGRADE + TOUGHBOOK PREFERRED
LOCATION
M: USA
UNCNDL1
Re: CF-52 Models
#9 Post by UNCNDL1 »
Here's a 2 pictures of the little red LED's at top right and left of the screen shining down on the keyboard on a CF-52GUNBRAM
fredmau
Re: CF-52 Models
#10 Post by fredmau »
Shawn wrote: Mon Oct 21, 2013 11:44 am If we're starting a FAQ..
I used to have a CF-52 i5-2520, it definitely still had an IDE media bay. Which sucked because the DVD had died and by 2018 or 2019 you couldn't buy a "new" IDE laptop DVD drive that hadn't been sitting around deteriorating in a hot warehouse for 5 years or more.
Formerly: CF-18 Snap-On Tools / Toyota Techstream version, CF-19 Mks 3,4,5, CF-28, CF-29, CF-30, CF-52, CF-T7
Currently Using: CF-C2 w/ CF-VEBC21 Dock, CF-54 with CF-VEB541 Dock, FZ-G1 w/ Havis automotive dock.
